Setting Map Distance Units to Degrees Minutes Seconds
1134
02-18-2014 01:55 PM
MikeBallard
I have a button in my Addin that changes the Data Frame display distance units to decimal degrees, which works well:
IMxDocument mxDoc = ArcMap.Document;
ESRI.ArcGIS.Carto.IActiveView activeView = mxDoc.ActiveView;
IPageLayout pageLayout = activeView as IPageLayout;
IMap map = activeView.FocusMap;
map.DistanceUnits = esriUnits.esriDecimalDegrees;
My problem is I would like to have a button that changes the map distance units to Degrees Minutes Seconds. I can do it manually through the Data Frame properties dialog box, but I am searching for a C#/ArcObjects way to do that.
SachinKanaujia
You can try using ILatLonFormat2 Interface. This is not a tested code but giving you some directions.
    Dim pLatLonFormat As ILatLonFormat2
    Set pLatLonFormat = New LatLonFormat
    With pLatLonFormat
        .ShowZeroMinutes = True
        .ShowZeroSeconds = True
    End With
    Dim pReportUnitFormat2 As IReportUnitFormat2
    Set pReportUnitFormat2 = pMXDoc
    pReportUnitFormat2.CoordinateReadoutUnits = esriDecimalDegrees
    Set pReportUnitFormat2.CoordinateReadoutLatLonFormat = pLatLonFormat
I Hope this helps
