Setting labels in a legend
1196
02-06-2011 11:59 AM
DavidKelly1
I have code that sets the colors for features using a unique renderer.  How do I set a description for each unique rederer in the legend?  If anyone has any examples or can point me toward one I would appreciate it.
Thanks for your help.
David Kelly
DavidKelly1
Below is the code I am using.  It reads a sorted table in an access database to get the values to be rendered and the RGB values for their colors. I am having trouble setting the label values for each  value rendered.  The label values are stored in a field in the table.
Any help would be appreciated.
David Kelly
Private Sub standardCats(SomeLayer As IGeoFeatureLayer)
On Error GoTo Errorhandler
    Dim pUVRenderer As IUniqueValueRenderer
    Set pUVRenderer = New UniqueValueRenderer
    pUVRenderer.FieldCount = 1
    pUVRenderer.Field(0) = "PM"
    Dim pFLayer As IFeatureLayer, pFClass As IFeatureClass
    Set pFLayer = SomeLayer
    Set pFClass = pFLayer.FeatureClass
    Dim pFCursor As IFeatureCursor
    Set pFCursor = pFClass.Search(Nothing, False)
    Dim pfeature As IFeature, pSym As ISimpleFillSymbol
    Set pfeature = pFCursor.NextFeature
    Dim pColor As IRgbColor
    Set pColor = New RgbColor
    Dim pVsTable As ITable
    Dim pVsCursor As ICursor
    Dim pRow As IRow
    Dim PM As Long
    Dim pDoc As IMxDocument
    Set pDoc = ThisDocument
    Dim Trans As Integer
    Dim pFeatws As IFeatureWorkspace
    Dim pTables As IStandaloneTableCollection
    Dim pTable As ITable
    Dim pFact As IWorkspaceFactory
    Dim pWorkSpace As IWorkspace
    Set pFact = New AccessWorkspaceFactory
    Set pWorkSpace = pFact.OpenFromFile("C:\SmokeTools\VSmoke\Vsmoke.mdb", 0)
    Set pFeatws = pWorkSpace
    Set pTable = pFeatws.OpenTable("Cat_AQI_PM_Hourly")
    Dim pStTab As IStandaloneTable
    Set pStTab = New StandaloneTable
    Set pStTab.Table = pTable
    Dim pCursor As ICursor
    Dim OldValue As Double
    Dim pTabCursor As ICursor
    Dim LabelCount As Integer
    Dim x As String
    LabelCount = 1
    Set pTabCursor = pStTab.Table.Search(Nothing, False)
    Set pRow = pTabCursor.NextRow
    Do Until pfeature Is Nothing
        PM = pfeature.Value(pFClass.FindField("PM"))
        OldValue = 0
        While Not pRow Is Nothing
               If PM > OldValue And PM <= pRow.Value(1) Then
                  Set pSym = New SimpleFillSymbol
                  pColor.RGB = RGB(pRow.Value(3), pRow.Value(4), pRow.Value(5))
                  pSym.Color = pColor
                  pUVRenderer.AddValue _
                  pfeature.Value(pFClass.FindField("PM")), "PM", pSym
                  'pUVRenderer.label(0) = pRow.Value(2)
                  Trans = pRow.Value(6)
                End If
            OldValue = pRow.Value(1)
            LabelCount = LabelCount + 1
        Wend
        Set pTabCursor = Nothing
    Loop
    If TypeOf SomeLayer Is ILayerEffects Then
      Dim pLayerEffects As ILayerEffects
      Set pLayerEffects = SomeLayer
      pLayerEffects.Transparency = Trans
    End If
    Set SomeLayer.Renderer = pUVRenderer
    '** Refresh the TOC
    pDoc.ActiveView.ContentsChanged
    pDoc.UpdateContents
     '** Draw the map
    pDoc.ActiveView.Refresh
    Exit Sub
Errorhandler:
    MsgBox "Error in UniqueValueRenderer"
End Sub
