Set target layer: ErrHRESULT E_FAIL has been returned from a call to a COM component.
2131
01-05-2011 10:54 AM
by Anonymous User
Not applicable
Original User: helenchu
All,
I have Error HRESULT E_FAIL has been returned from a call to a COM component when trying to set a edit target layer.  Below is what I have (vs2008, addin button).  I could get the msgbox to show the FeatureLayerName fine then it throws error at the 'exit for'.  I tried to create a new clean mxd application, didn't fix it.  I looked everywhere but couldn't find a solution.  These line of codes worked in my vb 6.0 with a few changes.  In vb 6.0 I passed pApp as AppRef not as IApplication & pMap = pEditor.Map
Any help is greatly appreciated.
Public Function setTargetLayer(ByVal strLayerName As String, ByVal pApp As ESRI.ArcGIS.Framework.IApplication) As IFeatureLayer
        Dim i, z As Integer
        Dim pMap As IMap
        Dim pComLayer As ICompositeLayer
        Dim pLayer As ILayer
        Dim pFlayer As IFeatureLayer
        Dim pEditLayers As IEditLayers
        Dim pUID As New UID
        Dim pEditor As IEditor
        Dim pDoc As IMxDocument
        pUID.Value = "esriEditor.Editor"
        pEditor = pApp.FindExtensionByCLSID(pUID)
        pDoc = pApp.Document
        pMap = pDoc.FocusMap
        pEditLayers = pEditor
        Try
            'Set Target Layer
            For i = 0 To pMap.LayerCount - 1
                If TypeOf pMap.Layer(i) Is IFeatureLayer Then
                    pLayer = pMap.Layer(i)
                    If UCase(pLayer.Name) = UCase(strLayerName) Then
                        If pEditLayers.IsEditable(pLayer) Then
                            pFlayer = pLayer
                            setTargetLayer = pFlayer
                            MsgBox(FeatureLayerName:" & pFlayer.Name)
                            Exit For
                        Else
                            MsgBox("this layer is not editable")
                            Exit Function
                        End If
                    End If
                Else
                    If TypeOf pMap.Layer(i) Is ICompositeLayer Then
                        pComLayer = pLayer
                        For z = 0 To pComLayer.Count - 1
                            If UCase(pComLayer.Layer(z).Name) = UCase(strLayerName) Then
                                If pEditLayers.IsEditable(pComLayer.Layer(z)) Then
                                    pFlayer = pComLayer.Layer(z)
                                    Exit For
                                Else
                                    MsgBox("This layer is not editable")
                                    Exit Function
                                End If
                            End If
                        Next z
                    End If
                End If
            Next i
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.Message)
        End Try
    End Function
helenchu
I was wrong.  After taking a closer look the error was thrown at
pEditLayers.SetCurrentLayer(pFlayer, 1) in my form
codes:
pFlayer = setTargetLayer(strTargetLayer, m_application)  --> this function works fine
any idea why I can't use pEditLayers.SetCurrentLayer?
Thank you
helenchu
I figure it out.  I used the wrong subtype, it should be 0 instead of 1.
