Retrieving the COM class factory for component with CLSID : error: 80040111
3757
8
05-02-2014 10:15 AM
srikanthpilli
I am working on migrating 9.3 Arc GIS Engine application to 10.1 Arc GIS Engine application. Everything is working good but at one of the following line(Dim pCalc2 As ICalculator = New ESRI.ArcGIS.GeoDatabaseUI.Calculator()) - I am getting the following message :
Retrieving the COM class factory for component with CLSID {D676066E-38CA-429A-B846-DA7A8446C52D} failed due to the following error: 80040111.
Any suggestions would be helpful.
Thanks.
NeilClemmons
Honored Contributor
ICalculator is a Desktop interface.  It is not installed by the Engine product.  This is the case with any interface or class that is part of an ArcObjects library whose name ends with UI.
srikanthpilli
Thanks Neil for your suggestions.
But, still we used the same code for 9.3 but when we migrated to 10.1 - we are facing this error message.
NeilClemmons
Honored Contributor
The reason for the error is clear - you're trying to use a Desktop-only interface in an Engine application.  If the only thing you have installed on the target machine is the Engine runtime then that interface is not there because Engine doesn't install it.
srikanthpilli
Hi Neil,
Thanks for sharing your wisdom.
On the box where I am running the Arc GIS Engine application - I have Arc GIS Desktop & Arc GIS Engine SDK & Runtime, vs 2010.
Below is the code url, from which I did used a part of it - and it is at this point (Set pCalc = New Calculator) - I am getting the error message.
http://resources.esri.com/help/9.3/arcgisengine/arcobjects/esriGeoDatabaseUI/ICalculator_Example.htm
Srikanth
NeilClemmons
Honored Contributor
Is your Engine application binding to the Desktop product and checking out a Desktop license?
srikanthpilli
Yes Neil, the Engine application is binding to Desktop product and checking out for Desktop License.
This is how the code looks when the form gets loaded :
  Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
        ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.EngineOrDesktop)
        Dim ESRI_SW_CLASS As String = UCase(Environ("ESRI_SOFTWARE_CLASS"))
        Dim ARCGIS_LICENSE As String = UCase(Environ("ARCGIS_LICENSE_FILE"))
        Dim ESRI_SEAT_PREF As String = UCase(Environ("ESRI_SEAT_PREFERENCE"))
        pnlZoomToBtn.BackColor = AxToolbarControlMap.BackColor
        'Create a new AoInitialize object
        m_pAoInitialize = New AoInitialize
        If IsNothing(m_pAoInitialize) Then
            MsgBox("Unable to initialize. This application cannot run!", MsgBoxStyle.MsgBoxSetForeground, "Error")
            Me.Close()
            Exit Sub
        End If
        Dim licenseStatus As esriLicenseStatus
        If (ESRI_SEAT_PREF = "FLOAT") Then
            If (ESRI_SW_CLASS = "VIEWER") Then
                licenseStatus = CheckOutLicenses(esriLicenseProductCode.esriLicenseProductCodeBasic)
                'Not licensed
                If (licenseStatus = esriLicenseStatus.esriLicenseNotLicensed) Then
NeilClemmons
Honored Contributor
You're binding call is set to Engine or Desktop.  Try changing that to Desktop only.  The way you have it now it could be binding to the Engine product, which doesn't include the interface you're trying to use.
srikanthpilli
Thanks a lot Neil.
I really appreciate for taking time from schedule and replying to my message.
It's really nice of you.
Your solution did resolved my issue.
