remove feature from current selection
1693
04-28-2011 05:11 AM
MichaelBreitfeld
is it possible to remove/unselect features from current selection programmatically? Why?
At the end, I have only one / the last feature in my selection!
Here is my Code example C#:
IMap pMap = axMapControl1.Map;
int SelObjects = pMap.SelectionCount;
IEnumFeature pEnumfeat;
IFeature pFeature;
pEnumfeat = pMap.FeatureSelection as IEnumFeature;
pFeature = pEnumfeat.Next();
for (int i = 1; i < SelObjects; i++)
                //?????? remove feature from current selection
Thank you!
ChaoWang
Have you tried ISelectionSet.RemoveList Method? Please note that if you are developing.NET or Java applications, call IGeoDatabaseBridge2.RemoveList instead.
ISelectionSet.RemoveList() in C#
http://forums.esri.com/thread.asp?c=93&f=993&t=184072
ISelectionSet Interface
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/ISelectionSet_Interface/...
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#/RemoveList_Method/002500...
IGeoDatabaseBridge2.RemoveList Method
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//00250000039m000000
