Refresh open Table in Arcamp
4451
14
09-15-2013 04:19 AM
UrsRichard
I "stamp" a position with the GPS-Tool to the Log-File saved in a filegeodatabase. In the map and the table window I always like to show the actual Log-File. I can refresh the view but not the opened table window. I always have to close and open the table window. I tried to refresh the table but nothing seems to have the effect to reload the actual data from the underlying featureclass (log-file). How can refresh the table window?
Dim pCmdItem As ICommandItem
            Dim pUID As New UIDClass()
            pUID.Value = "{256176AD-0C33-406C-9ED8-9F7AC784A3E3}"
            pCmdItem = My.ArcMap.Application.Document.CommandBars.Find(pUID)
            pCmdItem.Execute()
            Dim tableWindow As ITableWindow3 = New TableWindow
            Dim pSet As ISet = Nothing
            tableWindow.Application = My.ArcMap.Application
            tableWindow.FindOpenTableWindows(pSet)
            pSet.Reset()
            tableWindow = pSet.Next
            While Not tableWindow Is Nothing
                If tableWindow.IsOpen Then
                    tableWindow.TableControl.RemoveAndReloadCache()
                    tableWindow.Refresh()
                End If
            End While
RichardFairhurst
I am not sure I have a solution, but I am curious why you didn't use the TableControl Redraw method?
                    tableWindow.TableControl.Redraw()
UrsRichard
Still no success. Are there other solutions refreshing an open attribute table in ArcMap?
            pCmdItem.Execute()
            pSet.Reset()
                End If
            End While
AlexanderGray
Honored Contributor
if you reload cache for the GUI do you get the new rows?  Have you tried callind EditChanged on the Table view before removeAndReloadCache?  The GUI's ability to refresh the table depends on how the edit was done.  In an edit session with an edit operation, the proper messages to say the table was updated should have been sent, it is quite tricky.
UrsRichard
I don't get new Rows and EditChange work neither.
            pCmdItem.Execute()
            pSet.Reset()
                    tableWindow.TableControl.EditChanged()
                End If
            End While
LeoDonahue
UrsRichard
Still no refreshing. But if I reorder the Table with the GUI the attribute table will be reloaded correct. Is there a way to reorder the open attribute table with ArcObjects?
LeoDonahue
Explain?
AlexanderGray
Honored Contributor
Do you have a query filter on the layer by any chance?
UrsRichard
Explain?
I can reorder the table either with close and reopen again or with resorting the the table. Both ways work only manualy (working with the the mouse) in ArcMap.
