Problems with IXMLPropertySet SetPropertyX
1175
11-04-2011 08:11 AM
AndrewEgleton
I need to update some ArcGIS 10 metadata in files that have had their metadata upgraded from ArcGIS 9 FGDC metadata. Most things seem to work fine, but if I try the code bellow it will only work if the tags exist already:
pXMLProps.SetPropertyX( _
     "dataIdInfo/resConst/LegConsts/othConsts[../accessConsts/RestrictCd/@value='008']", _
     strAccess, esriXPTText, esriXSPAAddOrReplace, False)
There are a few other tags that use similar Xpaths and they are broken too, but all the tags with a straight forward tag work fine even when they aren't already present.
Any advice on how to resolve or work around this issue?
Andy
AlexanderGray
Honored Contributor
Do you have service pack 3 installed?  In my research I saw many fixes related to metadata in SP3.
AndrewEgleton
Yes, I have service pack 3 installed.
This issue only affects tags where there is a "partner" code value, which in the tags we are intrested in includes Originator, Publisher, and points of contact.
AndrewEgleton
While the code above still fails to work if the tags are missing, I have managed to resolve why the tags are missing!
The upgrade metadata tool at service pack 3 is creating incomplete metadata, going back to service pack 2 and using the upgrade metadata tool creates all the tags we need correctly.
