Problems running ExportActiveView sample with dynamic map enabled
702
04-07-2014 05:54 AM
ChristopherMeadows
I have used the ExportActiveView sample to successfully export the current map view to a JPG file.  However, when I change the map mode to dynamic and add a few items through a GraphicTracker and then try to run the ExportActiveview sample the items added through a GraphicTracker are not part of the outputted JPG.  If the dynamic mode is not enabled, the GraphicTracker items export correctly.
Does anyone know of a way of exporting the view successfully when a map is in dynamic mode?
Chris
