Problem in invoking method on IActiveViewEvents.FocusMapChanged Event
879
11-15-2010 01:31 AM
vijipat
Hi All,
I am simply trying to invoke a method on IActiveViewEvents' s FocusMapChanged Event. But somehow method  given for its handler is not getting invoked on focusMap Change Event.
Following is the code I have used:
private IActiveViewEvents_FocusMapChangedEventHandler DFocusMapChangedE;
private Map m_map;
m_map = (Map)m_mxDoc.FocusMap;
DFocusMapChangedE = new IActiveViewEvents_FocusMapChangedEventHandler(PerformSelectionChanged);
m_map.FocusMapChanged += DFocusMapChangedE;
Similar code on writing for SelectionChanged Event gets involked properly on selection Change Event.
Please help.
Regards,
Viji
SandhyaYamarthi
You dont need to define any eventhandlers, you can try directly the inbuilt 'IActiveViewEvents_Event' interface from Carto library and call the 'FocusMap Changed' event on map.
try this code: (I'm working with ArcGIS 10 now, so the code is relevant to 10 APIs)
ESRI.ArcGIS.Carto.IActiveViewEvents_Event avEvent = ArcMap.Document.FocusMap as ActiveViewEvents_Event;
avEvent.FocusMapChanged += new ESRI.ArcGIS.Carto.IActiveViewEvents_FocusMapChangedEventHandler(avEvent_FocusMapChanged);
and now you can write what ever you want to implement on focus map changed.
void avEvent_FocusMapChanged)
    //....code to do what ever you like to..
Let me know if you you still have any question on it.
Thanks!
