Printing field name and rows
779
01-13-2014 02:40 AM
jayakumar
IMapDocument pmd = new MapDocumentClass();
            if (pmd.get_IsMapDocument(@"F:/Projects/Inprogress.mxd"))
                pmd.Open(@"F:/Projects/Inprogress.mxd", null);
                IMap pmap;
                for (int i = 0; i <= pmd.MapCount - 1; i++)
                    pmap = pmd.get_Map(0);
                    Console.WriteLine(pmap.Name);
                    for (int layerIndex = 0; layerIndex < pmap.LayerCount; layerIndex++)
                        ILayer layer = pmap.get_Layer(layerIndex);
                        IFeatureLayer FL = layer as IFeatureLayer;
                        Console.WriteLine(FL.Name);
   After this I want to print the Field names of each class and the containing attributes, how to do that in next steps.
DuncanHornby
MVP Notable Contributor
As you are getting IFeatureLayers you would then get a handle on the FeatureClass. This gives you access the Fields which you can iterate over to retrieve the field names. If you want to read the actual values of each Feature then you need to create a FeatureCursor and iterate over this. There are many examples in the help and on this forum.
