Plug-in Data Source - Geographic Coordinate System
3416
10-12-2012 12:01 PM
GregFinch
We're building a plug-in data source.  The data is typical WGS1984 lat/lng data.  In the plugin data source, we're creating the spatial reference with code similar to the following:
var spatialReferenceFact = new SpatialReferenceEnvironmentClass(); shapeField.SpatialReference_2 = spatialReferenceFact.CreateGeographicCoordinateSystem(6326);
Problem is, when I try to drop the plug-in data source on a map, I get the following error:
Error opening feature class.  The specified WKID (factory code) or WKT (definition string) is not a Projected Coordinate System.
I'm curious why it's wanting a projected coordinate system.  According to the docs, I should be able to use a Geographic Coordinate System with a plug-in data source.
Any suggestions?
MelitaKennedy
Esri Notable Contributor
Hi Greg,
You're creating a datum, not a geographic coordinate system. Try using 4326 rather than 6326!
geographic coordinate system: name, datum (spheroid), prime meridian, angular unit
Melita
MelitaKennedy
Hi Greg,
Melita
GregFinch
Thank you!  That fixed it.
