Please help - DynamicMapEnabled causes the base map to not paint properly.
3351
03-17-2014 01:37 PM
RickeyTom
I have a base map (MillersRanch.mxd) loaded in ArcDesktop.
I am trying to add a dynamic layer on top of this.
But as soon as I call
ESRI.ArcGIS.Carto.IMap map = ArcMap.Document.FocusMap;
var dynamicMap = map as IDynamicMap;
dynamicMap.DynamicMapEnabled = true;
The base map does not paint properly.
Here is the scenario I have. I have a base map (MillersRanch.mxd).
[ATTACH=CONFIG]32256[/ATTACH]
As soon as I call the above code to enable dynamic views. The ArcDesktop does not seem to paint properly
In the picture below, the pipes and streets no longer paint.
[ATTACH=CONFIG]32257[/ATTACH]
And if Zoom further, areas in the base map does not paint.
[ATTACH=CONFIG]32258[/ATTACH]
What am I doing wrong?
Is this a bug in the arcDesktop or the ArcObjects sdk?
Any ideas would be greatly appreciated.
I had hacked apart my code. I am not even adding a dynamic  layer.
Does adding a real dynamic layer fix this? It did not for me, and that is why I started looking for the minimal changes that cause the painting problem.
This is one windows Server 2012.
