pan as my graphic tracker symbol moves
9458
36
08-14-2013 08:45 AM
DarcyHathaway
I need help to make the map pan as my graphic tracker symbol moves based on the GPS feed.
I am using Arc Object 10 with VS.net VB.
LeoDonahue
Did you try using this class?  com.esri.arcgis.carto.CenterAndScale
DarcyHathaway
The class com.esri.arcgis.carto.CenterAndScale looks like it is for Java and I am creating this in a windows PC application.
LeoDonahue
DarcyHathaway
Yes I have tried that and that is what is causing the blip because of the refresh.
DarcyHathaway
I took a closer look at the CoClasses and Classes that you sent me to look into and I cannot use this because it too is for a web application using a Mapserver and I am creating this application for a windows PC application using a Geo database.
LeoDonahue
Take a closer look.
Provides access to the Center And Scale Map Area Interface.
Product Availability Available with ArcGIS Engine, ArcGIS Desktop, and ArcGIS Server.
LeoDonahue
Sorry Darcy, that example uses MapServer, why?  I have no idea. But it will work with desktop.
And, I thought you said that this solution causes a blip anyway?
DarcyHathaway
Well I had to take a closer look and see if I was missing something.
I am not using desktop either, I am using Visual Studio .net.
Do you have an example?
LeoDonahue
So.... that leaves us with ArcGIS Engine?  And that class is still supported there also.
DarcyHathaway
And yes ArcGIS Engine is what i am using.
Okay please help me figure out if it will work.
