Objects in this class cannot be updated outside of an edit session[NE.EQUIPMENT]
4076
06-03-2011 07:23 AM
srinivasaparadesi
Hi All,
In need of urgent help.
I am trying to update a featureclass without help of IMap and IDocument. But i am repeateadly getting an error saying 'Objects in this class cannot be updated outside of an edit session[NE.EQUIPMENT]'. Please see the below code and let me is this possible or let me know an alternative. My general concept is not to use IMap or IDocument.
I am using
ArcGIS Desktop 9.3
Visual studio 2010(C#).
ESRI.ArcGIS.esriSystem.IAoInitialize arcLicense = new ESRI.ArcGIS.esriSystem.AoInitialize();
                ESRI.ArcGIS.esriSystem.IPropertySet PSC = new ESRI.ArcGIS.esriSystem.PropertySetClass();
                arcLicense.Initialize(ESRI.ArcGIS.esriSystem.esriLicenseProductCode.esriLicenseProductCodeArcView);
                PSC.SetProperty("SERVER", "1.1.1.1");
                PSC.SetProperty("INSTANCE", "1111");
                PSC.SetProperty("USER", "QA");
                PSC.SetProperty("PASSWORD", "******");
                PSC.SetProperty("DATABASE", "TESTDB");
                PSC.SetProperty("VERSION", "SDE.DEFAULT");
                ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactory workspaceFactory = new ESRI.ArcGIS.DataSourcesGDB.SdeWorkspaceFactory();
                ESRI.ArcGIS.Geodatabase.IWorkspace workspace = workspaceFactory.Open(PSC, 0);
                ESRI.ArcGIS.Geodatabase.IFeatureWorkspace featureWorkspace = (IFeatureWorkspace)workspace;
               IVersionedWorkspace versionedWorkspace = (IVersionedWorkspace)workspace;
                IVersion qaVersion = versionedWorkspace.FindVersion("SDE.DEFAULT"); //APATEL.NEW WO   SDE.DEFAULT
                ESRI.ArcGIS.Geodatabase.IFeatureClass featureClass = ((IFeatureWorkspace)qaVersion).OpenFeatureClass("NE.EQUIPMENT");
                IMultiuserWorkspaceEdit muWorkspaceEdit = (IMultiuserWorkspaceEdit)workspace;
                IWorkspaceEdit workspaceEdit = (IWorkspaceEdit)qaVersion;
                // Start a versioned edit session and an edit operation.
                muWorkspaceEdit.StartMultiuserEditing
                  (esriMultiuserEditSessionMode.esriMESMVersioned);
                workspaceEdit.StartEditing(false);
                workspaceEdit.StartEditOperation();
                if (workspaceEdit.IsBeingEdited())
                    IFeatureBuffer buffFeature = featureClass.CreateFeatureBuffer();
                    IFeatureCursor cur = featureClass.Insert(true);
                workspaceEdit.StopEditing(true);
                muWorkspaceEdit.StartMultiuserEditing(esriMultiuserEditSessionMode.esriMESMVersioned);
                IFeatureBuffer newFeature = featureClass.CreateFeatureBuffer();
                newFeature.Shape = oldFeature.ShapeCopy;
                featureClass.Insert(false);//getting exception here "Objects in this class cannot be updated outside an edit session [NE.EQUIPMENT]"
Please let me know if i need to provide any further information.
Thank you very much in advance.
Regards,
Srinivasa.
SebastiánVázquez
you might make sure that the featureclass you want to edit is opened for the first time after starting the edit session
in case that featureclass was already opened, try releasing it before starting the edit session
