Network flow trace with measures / distance
1162
06-14-2012 01:40 AM
SzymonPiskula
I wrote a tool that finds upstream and downstream trace in a river network from a start point X. This is based on a network flag for the point X. The network has defined flow direction/sinks. Now there is a requirement to find the distance of objects laying along the network (trace result in particular) to the point X. Is it possible for the network solver to add M Values to the resulting geometries? For example it would be enough if all the M Values would indicate how far a given FromPoint or ToPoint of the returned edge is from the end (last sink) of the whole 'branch'  of the river.  I''ve programmatically added  weights to the solver:
INetSchema netSchema = m_geometricNetwork.Network as INetSchema;
INetSolverWeightsGEN netSolverWeights = m_traceFlowSolver as INetSolverWeightsGEN;
INetWeight netWeight = netSchema.get_WeightByName("Distance");
netSolverWeights.FromToEdgeFilterWeight = netWeight;
netSolverWeights.ToFromEdgeFilterWeight = netWeight;
but the results have no measures.  Any suggestions?
Szymon
DuncanHornby
MVP Notable Contributor
Szymon,
It's been a long time time I've programmed a geometric network so I may be wrong here but I don't think you can mix M values with a geometric network, thats a linear referencing thing?
If your trace is returning a valid solution you can then enumerate the results using the Interface IEnumNetEID and build a polyline. You could then use the IMSegmentation3 Interface (once you made the polyline MAware) to calibrate M values to it. Then using the QueryPointAndDistance on the IPolyline interface you could "snap" your points to your measured trace polyline.
Duncan
SzymonPiskula
Duncan,
Thanks for the response. This IMSegmentation3  is almost fine, but... . If the trace result, say upstream, consist of several patsh that split (say in a form of Y letter) then the measures would go up one branch, (say up to upper left left point of Y letter). Then M values would continue from the middle of Y letter up to the right upper point. The more splits there are the less consistent/reliable M values become. In general this would work OK only for a single path without splits. Correct me if im wrong please !
Szymon
