Need help with ArcGIS developer tools in Visual Studio
3950
14
12-03-2012 05:53 AM
VidmantasAskinis
i need help with ArcMap developer tools. I'm trying to make an ArcMap command with Visual Studio 2010 in C# which deletes selected (could be all) points from point set.
I believe it should be a ArcMap basecommand.
I think i need to create an envelope to cover all the points in the layer. Then it should start editing and delete those points. But i'm a newbie at c# and Visual Studio. Could anyone give me code examples of using Ienvelope this way? Or something similar to learn from?
MarcinDruzgala
The thing is that points should be selected automatically (for example, all points in active view). And then deleted. It seems i forgot to mention it the beginning of this thread 🙂
Ye you did forgot to mention that 🙂
Ok here is the solution:
private IMxDocument MxDoc = ArcMap.Document;
protected override void OnClick()
 IActiveView activeView = MxDoc.ActiveView;
 IEnvelope env = activeView.Extent;
 IGeometry geom = (IGeometry)env;
 Map.SelectByShape(geom, null, false);
 activeView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection, null, env);
But here is the thing. It selects all features from ALL layers I don't know if that is a problem but you can later delete features only from one layer. Of course to do that you need to start edit session:)
There is one more option: before selecting by shape you can set the selectable property for feature layers that you don't want to be selected to false. I would do this like this:
IUID uid = new UIDClass();
uid.Value = "{40A9E885-5533-11D0-98BE-00805F7CED21}";
IEnumLayer enumLayerByName = Map.get_Layers((UID)uid, true);
enumLayerByName.Reset();
ILayer iLayer = enumLayerByName.Next();
while (!(iLayer == null))
 if (iLayer.Name != "your_layer_name")
  IFeatureLayer featLayer= (IFeatureLayer)iLayer;
  featLayer.Selectable = false;
Cheers
MDruzgala
VidmantasAskinis
Now i need help making the code.
You wrote "Map.get_Layers((UID)uid, true);" . Is "Map" an interface (private IMap Map)?
Here too: "Map.SelectByShape(geom, null, false);"
You also wrote   "editor = ArcMap.Application.FindExtensionByCLSID(uidEditor) as IEditor;"   and   "private IMxDocument MxDoc = ArcMap.Document;"  . Is "ArcMap" an "internal static class" like in
internal static class ArcMap
  private static IApplication s_app = null;
  private static IDocumentEvents_Event s_docEvent;
MarcinDruzgala
It's in every simple sample:
private IMap map = ArcMap.Document.FocusMap;
About ArcMap, yes it is this class. It's automatically generated.
MDruzgala
VidmantasAskinis
Works like a charm 🙂
But i see that it deletes all features (points, polylines etc.). How can i make it to delete only points and leave everything else in place? Add points to pointcollection and then delete? please help 🙂
MarcinDruzgala
If you want to delete features in specified layer you can do it this way:
privat void DeleteFeatures(IFeatureLayer featLayer)
      DeleteFeatures deleteFeatures = new DeleteFeatures();
      deleteFeatures.in_features = featLayer;
      RunTool(GP, deleteFeatures, null);
Cheers
MDruzgala
