memory is corrupt!!!
1003
06-01-2012 10:07 AM
MarAlcaraz1
I need to know if two TINs intersect each other and I am getting an Access Violation Exception:
"Attempted to read or write protected memory this is often an indication that other memory is corrupt."
when I use iRelationalOperator3D.disjoint3d or .IsNear3D in this code:
        Dim pTriangleED As IPolygon4
        Dim pTinPolygonED As ITinPolygon
        Dim pTriangleING As IPolygon4
        Dim pTinPolygonING As ITinPolygon
        Dim pRelOp3D As IRelationalOperator3D2
        Dim intersection As Boolean
        For i = 1 To pTinAdvTed.TriangleCount
            If pTinAdvTed.GetTriangle(i).IsInsideDataArea Then
                pTinPolygonED = pTinAdvTed.ExtractPolygon(pTinAdvTed.GetTriangle(i), Nothing, False)
                pTriangleED = pTinPolygonED.AsPolygon(Nothing, True)
                For j = 1 To pTinAdvTing.TriangleCount
                    If pTinAdvTing.GetTriangle(j).IsInsideDataArea Then
                        pTinPolygonING = pTinAdvTing.ExtractPolygon(pTinAdvTing.GetTriangle(i), Nothing, False)
                        pTriangleING = pTinPolygonING.AsPolygon(Nothing, True)
                        pRelOp3D = pTriangleED
                        intersection = pRelOp3D.IsNear3D(pTriangleING, 0)
                        MsgBox(intersection)
                    End If
            End If
Any idea why???
Thanks!!! Mar
