Match Table
637
10-21-2011 01:50 PM
MehdiSahlaei
I am having an issue with a application I have developed. This occurs when I am attempting to geocode a table. Most tables will geocode fine, however it seems on rare occasion this appears. I cannot seem to find an errors or symbols in the address or zipcode fields that would throw it off. I have geocoded tables throwing this error before in ArcMap fine with the exact same address locator created in the application, however I forgot to try that earlier on the customer PC so cannot guarantee the same thing applies here.
Here is the error I am receiving:
UtilsGeocode.cs GeocodeTableOfAddressesAdding Edit fields Adding Fields to be copied Creating output feature class Setting address fields Before Match table An invalid field name was used in a query string (Exception from HRESULT:0x80040204): Adding Edit Fields Adding Fields to be copied Creating output feature class Setting address fields Before Match table
Any help would be appreciated.
