Looking for arcobjects component for NAD_1983_To_WGS_1984_1 conversion
1557
5
01-07-2014 09:12 AM
ShaningYu
Honored Contributor
I am Looking for arcobjects component for NAD_1983_To_WGS_1984_1 conversion.  If you know the resource, please help.  Thanks.
MelitaKennedy
Esri Notable Contributor
Then you want the datum transformation equations/algorithms? One place is the EPSG aka OGP Geomatics Committee Guidance Note 7-2. This particular transformation uses a "3 parameter" transformation, geocentric translation. Many of the equation-based methods work in 3D Cartesian (XYZ) coordinates so you will have to implement lat/lon/h to/from XYZ converters too.
Melita
MelitaKennedy
The macro is esriSRGeoTransformation_NAD1983_To_WGS1984_1 but you can always use the well-known ID instead, 1188. You would use it to create a geotransformation that would then be used with the ProjectEx or ProjectEx5 methods.
Melita
ShaningYu
Honored Contributor
Thanks for your response.  Could you provide the details for the sources?
ShaningYu
Honored Contributor
Melita:  Actually, I need to the calculation formula or component for this conversion for dynamically converting some individual points.  Do you have any idea how to get it?  Thanks.
MelitaKennedy
Melita
ShaningYu
Honored Contributor
Thanks.  Will review the doc.
