Layers reference from Geoprocessing
4657
05-29-2015 01:56 PM
AbelPerez
ArcGIS 10.1: I am using ArcObjects in .NET with some geoprocessing. It works great. There is an option to add the resulting feature class to the map. That works great too. However how do I get a reference to this layer to move it to a group layer?
                Dim GP As GeoProcessor = New GeoProcessor
                GP.AddOutputsToMap = True 'True if we want to add outputs to map, False if we dont.
                Dim parameters As IVariantArray = New VarArray
                parameters.Add(inDatasets)
                parameters.Add(toPointFullName)
                parameters.Add("")
                Dim res As IGeoProcessorResult = GP.Execute("Merge_management", parameters, Nothing)
                'todo: how do I get a reference to ILayer of the resulting layer added to map?
~AGP
KenBuja
This is a function I use to return something from IGeoProcessorResult
    Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object
        Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue
        Dim InMemFC As String
        Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities
        Try
            GPVal = result.GetOutput(0)
            InMemFC = GPVal.GetAsText()
            Select Case Type
                Case "Feature Class"
                    Return GPUtil.OpenFeatureClassFromString(InMemFC)
                Case "Table"
                    Return GPUtil.OpenTableFromString(InMemFC)
                Case "Feature Layer"
                    Return GPUtil.OpenFeatureLayerFromString(InMemFC)
                Case Else
                    Return Nothing
            End Select
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString, "ReturnObjectfromResult error")
            Return Nothing
        End Try
    End Function
KenBuja
        Try
            Select Case Type
                Case "Table"
                Case Else
                    Return Nothing
            End Select
            Return Nothing
        End Try
    End Function
AbelPerez
Thanks. I think this will work although I have to set the GP.AddOutputsToMap = False otherwise it will get added twice.
