Labels showing through the callouts
1298
07-26-2010 01:59 PM
ericliprandi
Good Afternoon,
We are upgrading our app to 10.0. We currently display some information in callouts on the map in ArcMap. We are currently seeing labels through our callouts as shown in the attached picture.
As you may be able to see, there is a red "B" letter just by the the word. This is showing through the text box.
The code to display that is pretty simple and is posted below. We did not notice this issue with versions prior to 10.0. Just trying to identify if this is user error, new "feature" or other.
Eric.
using System;
using System.Drawing;
using System.Runtime.InteropServices;
using ESRI.ArcGIS.ArcMapUI;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Desktop.AddIns;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.Geometry;
using Point = ESRI.ArcGIS.Geometry.Point;
namespace ArcMapLabelsIssue
 public class EricTest : Button
  protected override void OnClick()
   //  TODO: Sample code showing how to access button host
   ArcMap.Application.CurrentTool = null;
   var doc = (IMxDocument) ArcMap.Application.Document;
   var view = (IActiveView) doc.FocusMap;
   var center = new Point {X = (view.Extent.XMin + view.Extent.XMax)/2, Y = (view.Extent.YMin + view.Extent.YMax)/2};
   IElement element = GetElement(center);
   element.Activate(view.ScreenDisplay);
   IGraphicsContainer container = GetGraphicsContainer();
   container.AddElement(element, 0);
   view.Refresh();
   view.ScreenDisplay.UpdateWindow();
  protected override void OnUpdate()
   Enabled = ArcMap.Application != null;
  private IElement GetElement(IPoint origin)
   const string text = "This is what I want to see in the box";
   var myColor = new RgbColorClass
                   Red = Color.LightYellow.R,
                   Green = Color.LightYellow.G,
                   Blue = Color.LightYellow.B
   const double textSize = 8.0d;
   const string fontName = "Arial";
   var textElement = new TextElementClass
                       Text = text,
                       HorizontalAlignment = esriTextHorizontalAlignment.esriTHALeft
   IPoint point = origin;
   //Set the location of the balloon callout
   IPoint textElementPoint = new PointClass();
   textElementPoint.PutCoords(origin.X, origin.Y);
   //   textElementPoint.Project(_map.SpatialReference);
   textElement.Geometry = textElementPoint;
   //Mark the element with a custom property
   ISimpleFillSymbol smplFill = new SimpleFillSymbolClass
                                  Color = myColor,
                                  Style = esriSimpleFillStyle.esriSFSSolid
   var blnCallout = new BalloonCalloutClass
                      Style = esriBalloonCalloutStyle.esriBCSRoundedRectangle,
                      Symbol = smplFill
   //Set the text element symbology to a default balloon callout
   var textSymbol = new TextSymbolClass
                      Background = blnCallout,
                      HorizontalAlignment = esriTextHorizontalAlignment.esriTHALeft,
                      VerticalAlignment = esriTextVerticalAlignment.esriTVATop
   //Set the location of the callout anchor
   IPoint anchorPoint = point;
   anchorPoint.Y = origin.Y;
   anchorPoint.X = origin.X;
   blnCallout.AnchorPoint = anchorPoint;
   textElement.Symbol = textSymbol;
   //Custom Property will store true for region text and false for ballons
   textElement.CustomProperty = false;
   textElement.Size = textSize;
   textElement.FontName = fontName;
   textElement.AnchorPoint = esriAnchorPointEnum.esriCenterPoint;
   textElement.ScaleText = true;
   return textElement;
  private IGraphicsContainer GetGraphicsContainer()
   var document = ArcMap.Application.Document as IMxDocument;
   if (document == null) return null;
   IMap map = document.FocusMap;
   double? referenceScale;
   try
    referenceScale = map.MapScale;
   catch (Exception)
    return null;
   var compositeGraphicsLayer = map.BasicGraphicsLayer as ICompositeGraphicsLayer;
   if (compositeGraphicsLayer == null) return null;
   IGraphicsLayer graphicsLayer;
   try
    graphicsLayer = compositeGraphicsLayer.FindLayer("Telvent007");
   catch (COMException)
    //When layer doesn't exist, it fires a COMException.
    graphicsLayer = null;
   //Graphical layer doesn't exist. We create one.
   if (graphicsLayer == null)
    //In case there were any displayed element, context should be deleted.
    graphicsLayer = compositeGraphicsLayer.AddLayer("Telvent007", null);
    var layer = graphicsLayer as ILayer;
    if (layer == null) return null;
    map.ActiveGraphicsLayer = layer;
   var scale = graphicsLayer as IGraphicsLayerScale;
   if (scale == null) return null;
   scale.ReferenceScale = (double) referenceScale;
   return graphicsLayer as IGraphicsContainer;
PatrickBurke
Did you ever solve this problem?  I am having the same issue.  How can this be fixed?  Thanks.
