IWorkspaceEdit and mousedown
4277
10
04-02-2010 08:20 AM
TonyAlmeida
MVP Regular Contributor
I have tool that creates points based on clicks. Tool works great as a shapefile, but i can't seem to get to work on an SDE feature class.
I get the following error:
One or more layers failed to draw:
FDO error: 0
The requested operation is invalid on a closed state[TonyAddressPoints.DBO.Shared_Address_Points]
from what i have read i need to implement the StartEditing but i don't know how. I need some help on how to get this to work in a geodatabase.
Thanks.
Dim pFeature1 As IFeature
Dim tmpPoint1 As IPoint
Private Sub UIToolControl2_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
        'Adds a point to a shapefile
    Dim pMap As IMap
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Set pMap = pMxDoc.FocusMap
    'Get the first layer in the map
    Dim pFeatLyr As IGeoFeatureLayer
    Set pFeatLyr = pMap.Layer(0)
     'Create a point from the mouse down click
    Dim tmpPoint As IPoint
    Set tmpPoint = New Point
    Set tmpPoint = pMxDoc.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(x, y)
    'Get the feature class
    Dim pFClass As IFeatureClass
    Set pFClass = pFeatLyr.FeatureClass
    'Create the new point feature
    Dim pfeature As IFeature
    Dim dblDist As Double
    If button = 2 Then
        Set pFeature1 = Nothing
        Set tmpPoint1 = Nothing
        Exit Sub
    End If
    If pFeature1 Is Nothing Then
        If tmpPoint1 Is Nothing Then
            Set tmpPoint1 = tmpPoint
        Else
            Set pfeature = pFClass.CreateFeature
            Set pfeature.Shape = tmpPoint
            If Not tmpPoint1 Is Nothing Then
                dblDist = 0
                dblDist = GetDistance1(pfeature)
                pfeature.Value(pfeature.Class.Fields.FindField("Distance")) = dblDist
                pfeature.Value(pfeature.Class.Fields.FindField("SiteNum")) = (dblDist / 5.28) + InputBox("Enter Address Range") & ""
                pfeature.Store
            End If
            Set pFeature1 = pfeature
        End If
    Else
        If Not pFeature1 Is Nothing Then
            dblDist = 0
            dblDist = GetDistance(pFeature1, pfeature)
            pfeature.Store
        End If
    End If
    pMxDoc.ActiveView.Refresh
    pMxDoc.UpdateContents
End Sub
Function GetDistance1(pFeature1 As IFeature) As Double
    Dim pGeom1 As IGeometry
    Dim pGeom2 As IGeometry
    Dim pProx As IProximityOperator
    Set pGeom1 = tmpPoint1
    Set pGeom2 = pFeature1.Shape
    Set pProx = pGeom2
    dblDist = pProx.ReturnDistance(pGeom1)
    'MsgBox dblDist
    GetDistance1 = dblDist
End Function
Function GetDistance(pFeature1 As IFeature, pFeature2 As IFeature) As Double
    Set pGeom1 = pFeature1.Shape
    Set pGeom2 = pFeature2.Shape
    Set pProx = pGeom2
    'MsgBox dblDist
    GetDistance = dblDist
End Function
vamsi_Sai_KrihsnaNagavalli
HI, I am trying to get the screen coordinates when user clicks on the map. I am very new to arcObjects so Can any one tell how can I initialize the mouse down event on Imap in C#.
Thanks in Advance
