Issue with Geoprocessor.ExecuteAsync()
3372
06-11-2013 02:53 PM
TerryGiles
I'm trying to follow the asynch pattern described in the SDK sample "Executing geoprocessing tools in the background" (online  here) but keep getting a COMException in my ToolExecuted handler when I try dequeque the next tool call ExecuteAsync.
Event handlers are set in the constructor of the class -
            _gp = new Geoprocessor();
            _gp.ToolExecuted += new EventHandler<ToolExecutedEventArgs>(GPToolExecuted);
            _gp.ToolExecuting += new EventHandler<ToolExecutingEventArgs>(GPToolExecuting);
The first tool in my Queque is called in this method -
internal void RunTool(Queue<GPFunction> GPFuncs)
            //Runs a TauDEM GP tool.  Input GPFunction queue can also contain conversion & clean up GP tasks
            //since TauDEM only reads/write UnCompressed TIFFs
            GPFunction gpfunct = null;
            try
                _gpfunctions = GPFuncs;
                gpfunct = _gpfunctions.Dequeue();
                _gp.OverwriteOutput = true; // gpfunct.OverwriteOutput;
                _gp.AddOutputsToMap = gpfunct.AddtoMap;
                _gp.AddToolbox(_strTauDEM + "TauDEM5Arc\\TauDEM Tools.tbx");
                if (gpfunct.Environments != null)
                    foreach (KeyValuePair<string, object> kvp in gpfunct.Environments)
                        _gp.SetEnvironmentValue(kvp.Key, kvp.Value);
                _gp.ExecuteAsync(gpfunct.ToolName, gpfunct.ToolParams);
            catch (Exception ex)
                System.Diagnostics.Debug.WriteLine("Error in RunTool");
                System.Diagnostics.Debug.WriteLine(ex.Message);
The first tool (usally CopyRaster to convert to Tif which is the only input a custom tool will take) fires and and when it completes it will go into ToolExecuted but bombs on the ExecuteAsync
        private void GPToolExecuted(object sender, ToolExecutedEventArgs e)
            //Fires when a GP tool completes (fail or success)
            IGeoProcessorResult2 result = e.GPResult as IGeoProcessorResult2;
            if (result.Status == esriJobStatus.esriJobSucceeded)
                System.Diagnostics.Debug.WriteLine(result.Process.ToolName.DisplayName + " completed");
                if (_gpfunctions.Count > 0)
                    try
                        _gp.OverwriteOutput = true;  //gpfunct.OverwriteOutput;
                        _gp.ExecuteAsync(gpfunct.ToolName, gpfunct.ToolParams);                   //throws exception here
                        System.Diagnostics.Debug.WriteLine("Error in ToolExecuted");
            else
                System.Diagnostics.Debug.WriteLine(result.Process.ToolName.DisplayName + " did something else");
                IGPMessages msgs = result.GetResultMessages();
                for (int i = 0; i < result.MessageCount; i++)
                    IGPMessage msg = (IGPMessage)msgs.GetMessage(i);
                    System.Diagnostics.Debug.WriteLine(msg.Description);
If I click on the button on my form after the Exception occurs it will write my debug statements to the Output panel 2x.
Anyone have an idea what I'm doing wrong & why it seems to be executing the ToolExecuted handler 2x??
Terry
TerryGiles
The custom tool works fine if it's the 1st and only tool in the queue, but not if I have to run CopyRaster before hand to make a Tiff to pass to it.
I ended up switching to a synchronous pattern instead, that seems to work regardless of which tools are in my queue.  Not my preferred solution but it'll work for now..
            //since TauDEM only reads/writes UnCompressed TIFFs
            try
                foreach (GPFunction gpfunct in GPFuncs)
                    _gp.Execute(gpfunct.ToolName, gpfunct.ToolParams, null);
