Is it possible to save mxd to a previous version with ArcGIS Engine?
3435
09-11-2012 09:58 AM
ChrisKasturi
This is a post of a way to programmatically save an mxd to a previous version using ArcGIS Desktop.  However, I was wondering whether there is a similar functionality for engine?
Subject Re: Programmatically save a copy
Author Jeff Matson
Date Oct 05, 2005
Message Maybe try this; it seemed to work, you'll have to open the document using a password, in this case it's "open".
  'add above the application.saveas line
Application.LockCustomization "open", Nothing
  Jeff Matson
GIS Programmer/Analyst
[email protected]
DavidLednik
Doesn't look like it.
IMapDocument has Save and SaveAs methods but you can't specify a version
David
NeilClemmons
Honored Contributor
You should be able to QI from IMapDocument to IDocumentVersion, set the version property and save.
DavidLednik
True, but you would probably need to open existing MXD, change version and save it as new version?
NeilClemmons
Honored Contributor
That's pretty much what I said to do:
            Dim mapDocument As IMapDocument = New MapDocument
            mapDocument.Open("C:\temp\myMap_v10.mxd")
            DirectCast(mapDocument, IDocumentVersion).DocumentVersion = esriArcGISVersion.esriArcGISVersion93
            mapDocument.SaveAs("C:\temp\myMap_v93.mxd")
            mapDocument.Close()
