Invalid Procedure Call in IDataStatistics.Statistics
826
04-29-2011 08:13 AM
ScottMalcolm
I have some VBA code that worked fine in 9.3.1. My agency just upgraded to 10.0, and the code seems to work fine up to a call to IDataStatistics.Statistics. I do not recall seeing this on the deprecated functions list. The code (below) is a boilerplate for extracting max and min from a field. Any help (or suggestions for alternative coding) would be greatly appreciated!
Scott
Sub FindFieldExtremes(FieldName, LayerIndex, Zmax, Zmin)
    Dim pMxDoc As IMxDocument
    Dim pFLayer As IFeatureLayer
    Dim pData As IDataStatistics
    Dim pCursor As ICursor
    Dim pStatResults As IStatisticsResults
    Set pMxDoc = ThisDocument
    Set pFLayer = pMxDoc.FocusMap.Layer(LayerIndex)
    Set pCursor = Nothing
    Set pCursor = pFLayer.Search(Nothing, False)
    Set pData = New DataStatistics
    Set pData.Cursor = pCursor
    pData.Field = FieldName
    Set pStatResults = pData.Statistics  (ERROR APPEARS HERE)
    Zmax = pStatResults.Maximum
    Zmin = pStatResults.Minimum
End Sub
ScottMalcolm
I have discovered a problem earlier that is likely the cause of this error. I will work on it a bit before starting a new thread.
Thanks for the forum!
