Invalid ArcGIS runtime binding. Application will shut down.
4496
05-15-2013 09:58 PM
mdonnelly
Hello,
I have created a ArcGIS console stand alone application using the new project wizard in Visual Studio 2010.
The default code created in the stub was around grabbing a desktop license:
class Program
        private static LicenseInitializer m_AOLicenseInitializer = new SetCustomMapExtent.LicenseInitializer();
        [STAThread()]
        static void Main(string[] args)
            //ESRI License Initializer generated code.
            //m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeBasic, esriLicenseProductCode.esriLicenseProductCodeStandard, esriLicenseProductCode.esriLicenseProductCodeAdvanced },
            //new esriLicenseExtensionCode[] { });
            m_AOLicenseInitializer.InitializeApplication(new esriLicenseProductCode[] { esriLicenseProductCode.esriLicenseProductCodeAdvanced },
            //Do not make any call to ArcObjects after ShutDownApplication()
            m_AOLicenseInitializer.ShutdownApplication();
The problem is that when I compile this stub and run it, I get the error in the subject of this post.
I am running this application on a machine with ArcGIS Desktop 10.1 SP1 with an Advanced license (borrowed) installed on it.
Any help would be appreciated.
Regards,
Mark
Regards,
Mark
BarbaraSchneider1
Hello Mark,
try to run the commented out code, this may work:
Barbara
