Inserting Multiple Rows into Table
5691
17
01-28-2013 11:06 AM
JoshObrecht
I am trying to insert multiple rows into a Geodatabase table through VB, but for some reason the program crashes when trying to enter a new row when the table already contains a row. I'm not sure if there is a lock that is occurring or what is going on. I have tried using both cursors and IFeature.store. Has this occurred for anybody else and how were you able to solve it?
JoshObrecht
feature is declared at Dim feature As IRowBuffer.
And I can't move the OpenTable out as it is dependent on shape being equal to the feature's aliasname.
JeffMatson
Do you mean to be calling .Insert or .InsertRow on this line?
tableInsertCursor = outputSignDetailTable.InsertRow(True)
Also it looks like your string variable shape is set already to ArcMapAddin1.ArcGISAddin1.val, is it changing some other way so that you might be processing more than one type at a time?
shape = ArcMapAddin1.ArcGISAddin1.val
Do While pFeat IsNot Nothing
       If shape = pFeat.Class.AliasName Then
           outputSignDetailTable = DirectCast(workspace, IFeatureWorkspace).OpenTable(shape)
           tableBuffer = outputSignDetailTable.CreateRowBuffer()
           row = CType(tableBuffer, IRow)  '<-- is this used anywhere else?
           feature = tableBuffer  '<--- why not just use the tableBuffer object?
JoshObrecht
Good call on using shape in the table. Not sure why I didn't catch that. However, that's not the cause.
And I only used the following code as I saw someone else on here using it. I was trying to originally use CreateRow with some different code but it errored as well.
JeffMatson
If you step through your code one line at a time, on which line does the error occur?  I'm still confused how tableInsertCursor = outputSignDetailTable.InsertRow(True) would not cause a problem.
JoshObrecht
After testing it, that is in fact where the error is occurring now. Before it was occurring on the insert portion.
JoshObrecht
The error is occurring at tableInsertCursor = outputSignDetailTable.InsertRow(True).
JeffMatson
What happens when you try it using .Insert instead of .InsertRow?
JoshObrecht
That solved that issue. There was another error that was provided but I was able to resolve that. Thanks!
