Implementing IGPFunction - ParameterInfo
1053
06-06-2010 04:08 AM
BalajiViswanathan
I need to design my Front-end for a Geoprocessing tool with all the input parameters, for which i need to implement IGPFunction.
To get an input Featureclass from the user, my parameter is coded like this.
                Dim pParameters As IArray = New ArrayClass()
                'Input DataType is GPFeatureLayerType
                Dim inputParameter As IGPParameterEdit = New GPParameterClass()
                inputParameter.DataType = New GPFeatureLayerTypeClass()
                ' Default Value object is DEFeatureClass
                inputParameter.Value = New GPFeatureLayerClass()
                ' Set Input Parameter properties
                inputParameter.Direction = esriGPParameterDirection.esriGPParameterDirectionInput
                inputParameter.DisplayName = "Input Features"
                inputParameter.Name = "input_features"
                inputParameter.ParameterType = esriGPParameterType.esriGPParameterTypeRequired
                pParameters.Add(inputParameter)
This works fine. Now my task is to get a ComboBox, on click of the drop-down menu, i need to get the FieldNames of the input Feature class. (Refer the attached jpeg)
How do i code to get a parameter like this?
Expecting an answer.
JasonScheirer
Esri Alum
Set the Domain attribute on the Parameter object as a GPCodedValueDomain populated to your values.
