ILayer/IFeatureLayer to JSON
2019
5
05-01-2012 04:38 PM
JamesVillanueva
Is there a way of converting ILayer or IFeatuureLayer to JSON? The reason I ask is I do not always want to publish these as services and it would be nice to pass all features, attributes, and symbologies to the client.
nicogis
MVP Alum
DubravkoAntonic
Yes you can user REST service in ArcGis Server, but if you ask for Desktop evironment I don't know for that kind of object, and more of it I'm not sure why would use that.
Simple ILayer and IFeaturelayer converter to JSonLayer is done in one day.
Regards Dubravko
nicogis
MVP Alum
JamesVillanueva
Nico that worked great for featureclasses. Can something similar be done for renderers as well? Thanks.
nicogis
MVP Alum
I discover: in 10.1 you have available ESRI.ArcGIS.Geodatabase.IJSONConverterGdb (class JSONConverterGdb ) where you have available read and write recorset and query domain.
http://resourcesbeta.arcgis.com/en/help/arcobjects-net/componenthelp/index.html#//002500000nqz000000
for renderer do you mean renderer objects (chaption 15) geospecification esri? http://www.esri.com/library/whitepapers/pdfs/geoservices-rest-spec.pdf if yes I think that you must use IJSONWriter and read single properties of object render and serialze with IJSONWriter http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//004200000108000000
JamesVillanueva
Thanks again. This is exactly what I needed to know.
