IFeatureSelection :: Clear does not clear graphics selection
1699
06-04-2012 01:06 PM
SachaTousignant
Hello everyone,
I'm having trouble with the following :
I have a selection on features and store it into an IFeatureSelection. Then I clear the selection with the method Clear().
The featureselection is indeed empty, but on the map, I still see that the features are selected, but they are not really in reality.
// My selection of features IFeatureSelection plantSelection = infosXML.LayerPlant as IFeatureSelection; // Load of code ... // Clear the selection plantSelection.Clear();  // Refresh the screen ArcMap.Document.ActiveView.Refresh();
Any help would be REALLY appreciated! Ty all
SachaTousignant
You're calling Refresh on the document's active view.  If the document is in Layout view then this will refresh the layout and not the map inside of the map frame.  If the document is in Data view then this will refresh the map in the table of contents that is currently active.  If you are calling this code while in Data view and the map that contains the layer is active then this should work.  Otherwise, you will need to get the appropriate active view reference before calling Refresh.
Ty Neil for your reply, I found out how to fix my problem, here's the code in case someone else needs it
IActiveView activeView = ArcMap.Document.FocusMap as IActiveView; activeView.Refresh();
NeilClemmons
Honored Contributor
KenBuja
MVP Esteemed Contributor
This might be once of the cases where you have to refresh twice.
SachaTousignant
