IFeatureLayer count for a complex group layer? Similar to IMap.Layers property
1846
10-08-2013 01:09 PM
deleted-user-VeC5jUIlNXtq
This might be a lost cause, but worth a shot...
I'm curious about a potential functionality exactly like IMap.Layers, but instead of IMap, I want ICompositeLayer (or any reference to a group layer really).
I'm looking for the most elegant solution to getting a count of all IFeatureLayer layers, but only within a relatively complex group layer, not the entire map.
In my head, I would call ICompositeLayer.Layers(<insert IFeatureLayer UID here>, True), if it existed. But it doesn't, and I'm not sure if anything like it does.
Currently, the code I'm working with calls a function "GetNumLayers" which has a series of nested loops checking if a particular ILayer, is of type IFeatureLayer or not and adding +1 to the counter, and then returning the total. I'm convinced something faster exists as an alternative.
I think it would be a good learning experience, and to be honest, I'm really not worried about the time it takes, rather the "best" way to achieve this.
Any assistance would be much appreciated!
NeilClemmons
Honored Contributor
You can write a function that counts the feature layers in a given group layer by looping through the layers in that group layer.  For each layer, check the type.  If it's a feature layer, then add to the count.  If it's a group layer then call the function recursively and add it's return value to the layer count.  The function returns the count.
JohnStephens
I am not sure if I 100% understand, but you are trying to get at the layers in an ICompositeLayer?
Can't you just get the Count and then loop through the layers using the Layer[index]?
Sorry, hopefully this will help.
Unfortunately ICompositeLayer.Count would return a count similar to pMap.LayerCount wouldn't it?
The main group layer itself has multiple levels: sub-group layers and feature layers all kind of mixed in.
I'm looking for specifically: a count of feature layers (regardless of how deep they are). I don't want to include sub-group layers (that may contain feature layers), in that count. Only layers that are TypeOf IFeatureLayer.
Definitely an odd problem I'll admit that haha. Anyways, hopefully that clarifies things a little bit.
Thanks for the suggestion!
NeilClemmons
Honored Contributor
Hmmm, was hoping there would be a hidden property I wasn't aware of, oh well.
Currently, that's how the count is retrieved, though I didn't think about recursion, that's likely the faster method than a series of loops (also looks nicer).
Thanks Neil.
