IExtension example in C#  - event listener?
1169
05-11-2010 09:39 AM
VickiMartinez
Can anyone point me to a good example of IExtension in C#?  I have written a simple event listener, but I don't seem to be hooking it up quite right.  I want the listener to be on whenever ArcMap is on, so no interaction from the user is required to start the tool I will be writing - well, no action other than making a feature selection with the select tool.  I am listening for the "OnSelectionChanged()" event.
I have found plenty of examples of an event listener class, so I am fairly confident in that part of my code.  The difficulty seems to be in hooking it to the application.
Also, probably a more basic question - is this the right approach to inherit from IExtension for an event listener, or should I be inheriting from BaseTool and going at it from that direction (or something else entirely)?
Thanks very much for any input on this!
ModyBuchbinder
Hey
Check this example: http://resources.esri.com/help/9.3/ArcGISDesktop/dotnet/f90f78a3-6dcc-4a17-8e22-74c25c93eb4a.htm
It uses IExtension to wire events.
Have Fun
Mody
VickiMartinez
This is exactly what I was looking for.  Thanks!
