iexportoperation issue after migration to 10.1
2458
01-29-2014 09:50 AM
MikeZastre
Please help!!  After migrating my ArcEngine app from 9.3 to 10.1 I get an error trying to export a featureclass.  This issue just started after the application was moved to 10.1.  I've been stuck on this for days with no movement, please help.
The image below shows the error I am receiving.
[ATTACH=CONFIG]30946[/ATTACH]
NeilClemmons
Honored Contributor
What product is your application binding to before checking out a license?  The IExportOperation interface is only available with ArcGIS Desktop so unless you're binding to Desktop you won't be able to use it.
MichaelEber
You may want to check and see if they now have it named as ExportOperationClass.
Good luck with 10.1 -- we have one application that is waiting for a patch from ESRI due to bugs in their code..and others that are broken because of how they changed publishing services and storing results (which they never did before).
