IEditEvents when editing tables
2488
06-22-2016 10:35 AM
TheodoreRakel
I can use the IEditEvents to be notified of edits to features, but is there some way to be notified when the user in ArcMap makes changes to a table?  For example, if the user uses the Attributes window to update a field in a table, I would like to know that an update has happened.  I don't see IEditEvents_OnChangeFeature firing when I update an attribute in a table, which makes sense because it's not a feature that is changing.  What I'm looking for is something like IEditEvents_OnAnyChange, just so I know that the user is doing some kind of insert update or delete.  I'm using ArcMap 10.2.1.
JeffMatson
You can use IObjectClassEvents:
IObjectClassEvents Example
Just change it to use IStandAloneTable and ITable instead of IFeatureClass:
Private WithEvents ObjectClassEvents As ObjectClassEvents
Public Sub initEvents()
  Dim pMxdoc As IMxDocument
  Set pMxdoc = Application.Document
  Dim satColl As IStandaloneTableCollection
  Set satColl = pMxdoc.FocusMap
  Dim sat As IStandaloneTable
  Set sat = satColl.StandaloneTable(0)
  Dim t As ITable
  Set t = sat.Table
' Dim pFeatureLayer As IFeatureLayer
'  Dim pLayer As ILayer
'  Dim pFeatureClass As IFeatureClass
'  Set pLayer = pMxdoc.FocusMap.Layer(0)
'  Set pFeatureLayer = pLayer
'  Set pFeatureClass = pFeatureLayer.FeatureClass
  Dim pObjectClass As IObjectClass
'  Set pObjectClass = pFeatureClass
  Set pObjectClass = t
  Set ObjectClassEvents = pObjectClass
End Sub
Private Sub ObjectClassEvents_OnChange(ByVal obj As IObject)
  MsgBox "OnChange for: " & obj.OID
End Sub
Private Sub ObjectClassEvents_OnCreate(ByVal obj As IObject)
  MsgBox "OnCreate for: " & obj.OID
End Sub
Private Sub ObjectClassEvents_OnDelete(ByVal obj As IObject)
  MsgBox "OnDelete for: " & obj.OID
End Sub
JeffMatson
  Dim t As ITable
  Set t = sat.Table
End Sub
End Sub
End Sub
End Sub
