IBufferConstruction
1481
05-09-2012 06:28 AM
BennettChamberland
Everything seems to work fine, up until I actually create the buffer, then it doesn't do anything and has 0 shapebuffers. the geometry collection does have 1 object as it enters ConstructBuffers.
IGeometryPtr BufferGeometry(IGeometryPtr inShapePtr, double distance, esriBufferConstructionSideEnum side)
long buffCount = -1;
IBufferConstructionPropertiesPtr bufferProp(CLSID_BufferConstruction);
IBufferConstructionPtr bufferPtr = (IBufferConstructionPtr)bufferProp;
bufferProp->put_SideOption(side);
bufferProp->put_EndOption(esriBufferFlat);
bufferProp->put_ExplodeBuffers(VARIANT_FALSE);
bufferProp->put_OutsideOnly(VARIANT_FALSE);
bufferProp->put_GenerateCurves(VARIANT_FALSE);
bufferProp->put_UnionOverlappingBuffers(VARIANT_TRUE);
bufferProp->put_DensifyDeviation(-1);
if(!inShapePtr)
  return NULL;
IGeometryCollectionPtr geometryBag(CLSID_GeometryBag);
IGeometryBagPtr shapesBagPtr = (IGeometryBagPtr)geometryBag;
ISpatialReferencePtr spatialRefPtr;
inShapePtr->get_SpatialReference(&spatialRefPtr);
((IGeometryPtr)shapesBagPtr)->putref_SpatialReference(spatialRefPtr);
((IGeometryCollectionPtr)shapesBagPtr)->AddGeometry(inShapePtr, &vtMissing, &vtMissing);
((IGeometryCollectionPtr)shapesBagPtr)->get_GeometryCount(&buffCount);
IGeometryCollectionPtr shapebuffer(CLSID_GeometryBag);
((IGeometryPtr)shapebuffer)->putref_SpatialReference(spatialRefPtr);
HRESULT hr = bufferPtr->ConstructBuffers((IEnumGeometryPtr)shapesBagPtr, distance, shapebuffer);
if(shapebuffer)
  shapebuffer->get_GeometryCount(&buffCount);
return shapebuffer;
WeifengHe
Just from the code I don't see any problem.  Can you also please provide the input parameters?
BennettChamberland
Turned out to be an input error. The IGeometryPtr i was passing in wasn't correct some how so I changed my method of creating it and it works fine now. I'm not entirely sure why pulling a polyline from a layer didn't work, but building the line in memory does.
WeifengHe
Glad it works now.  Just for curiousity, how did you code to pull a polyline from the layer?
BennettChamberland
Before this I select a geometry within a specific layer
IGeometryPtr ClassName::GetSelectedShape(CString layerName)
IFeatureSelectionPtr featureSelection;
featureSelection = GetLayerByName(layerName);
if (!featureSelection)
  return NULL;
ISelectionSetPtr selectionSet;
featureSelection->get_SelectionSet(&selectionSet);
IEnumGeometryPtr enumGeometry;
enumGeometry.CreateInstance(CLSID_EnumFeatureGeometry);
IEnumGeometryBindPtr enumGeometryBind = enumGeometry;
enumGeometryBind->BindGeometrySource(NULL, selectionSet);
IGeometryPtr geometry;
enumGeometry->Next(&geometry);
return geometry;
