How to write this python geoprocessing lines in vb.net console application
932
06-12-2012 05:22 PM
JoseSanchez
Hi all
I am writing a console application and would like to know how to write these lines in vb.net
# Create empty Point and Array objects
point = arcpy.Point()
array = arcpy.Array()
# A list that will hold each of the Polygon objects
featureList = []
# point  point of the array in to close off the polygon
array.add(point)
# Add the first point of the array in to close off the polygon
    array.add(array.getObject(0))
# Create a Polygon object based on the array of points
polygon = arcpy.Polygon(array)
# Clear the array for future use
array.removeAll()
# Append to the list of Polygon objects
featureList.append(polygon)
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html - /Polygon/000v000000n1000000/
