How to write a code that counts the number of points inside each polygon?
3146
6
12-08-2010 01:01 PM
JamalNUMAN
Legendary Contributor
How to write a code VB ??? Arcobject that counts the number of points inside each polygon?
Please, see the attached image that shows my question
I???ve two layers, point layer and polygon layer, I need to write a code that calculate the number of points inside each polygon
Thank you
kalid
Jamal Numan
Venkata_RaoTammineni
Please find below code working fine for me...points count will be added into polygon layer ...updated into given filed.....
using System;
using System.Drawing;
using System.Runtime.InteropServices;
namespace CountPoints
    /// <summary>
    /// Summary description for CountAllPoints.
    /// </summary>
    [Guid("96ac8c8b-1a7c-457d-aa69-dcdcba6034f2")]
    [ClassInterface(ClassInterfaceType.None)]
    [ProgId("CountPoints.CountAllPoints")]
    public sealed class CountAllPoints : ESRI.ArcGIS.ADF.BaseClasses.BaseCommand
        #region COM Registration Function(s)
        [ComRegisterFunction()]
        [ComVisible(false)]
        static void RegisterFunction(Type registerType)
            // Required for ArcGIS Component Category Registrar support
            ArcGISCategoryRegistration(registerType);
            // TODO: Add any COM registration code here
        [ComUnregisterFunction()]
        [ComVisible(false)]
        static void UnregisterFunction(Type registerType)
            ArcGISCategoryUnregistration(registerType);
            // TODO: Add any COM unregistration code here
        #region ArcGIS Component Category Registrar generated code
        /// <summary>
        /// Required method for ArcGIS Component Category registration -
        /// Do not modify the contents of this method with the code editor.
        /// </summary>
        private static void ArcGISCategoryRegistration(Type registerType)
            string regKey = string.Format("HKEY_CLASSES_ROOT\\CLSID\\{{{0}}}", registerType.GUID);
            ESRI.ArcGIS.ADF.CATIDs.MxCommands.Register(regKey);
        /// <summary>
        /// Required method for ArcGIS Component Category unregistration -
        /// </summary>
        private static void ArcGISCategoryUnregistration(Type registerType)
            ESRI.ArcGIS.ADF.CATIDs.MxCommands.Unregister(regKey);
        #endregion
        #endregion
        private ESRI.ArcGIS.Framework.IApplication m_application;
        public CountAllPoints()
            // TODO: Define values for the public properties
            base.m_category = "Spatial Analsis"; //localizable text
            base.m_caption = "Spatial Analsis";  //localizable text
            base.m_message = "Counts the point inside the polygon";  //localizable text
            base.m_toolTip = "Counts the point inside the polygon";  //localizable text
            base.m_name = "Spatial_Points_Inside_Polygon";   //unique id, non-localizable (e.g. "MyCategory_ArcMapCommand")
            try
                // TODO: change bitmap name if necessary
                string bitmapResourceName = GetType().Name + ".gif";
                base.m_bitmap = new Bitmap(GetType(), bitmapResourceName);
            catch (Exception ex)
                System.Diagnostics.Trace.WriteLine(ex.Message, "Invalid Bitmap");
        #region Overriden Class Methods
        /// <summary>
        /// Occurs when this command is created
        /// </summary>
        /// <param name="hook">Instance of the application</param>
        public override void OnCreate(object hook)
            if (hook == null)
                return;
            m_application = hook as ESRI.ArcGIS.Framework.IApplication;
            //Disable if it is not ArcMap
            if (hook is ESRI.ArcGIS.ArcMapUI.IMxApplication)
                base.m_enabled = true;
            else
                base.m_enabled = false;
            // TODO:  Add other initialization code
        /// <summary>
        /// Occurs when this command is clicked
        /// </summary>
        public override void OnClick()
            // TODO: Add CountAllPoints.OnClick implementation
            ESRI.ArcGIS.ArcMapUI.IMxDocument pMxDoc = m_application.Document as ESRI.ArcGIS.ArcMapUI.IMxDocument;
            ESRI.ArcGIS.Carto.IFeatureLayer pPolygonLayer = pMxDoc.FocusMap.get_Layer(1) as ESRI.ArcGIS.Carto.IFeatureLayer;
            ESRI.ArcGIS.Carto.IFeatureLayer pPointLayer = pMxDoc.ActiveView.FocusMap.get_Layer(0) as ESRI.ArcGIS.Carto.IFeatureLayer;
            ESRI.ArcGIS.Editor.IEditor pEditor;
            ESRI.ArcGIS.esriSystem.UID pUID = new ESRI.ArcGIS.esriSystem.UIDClass();
            pUID.Value = "esricore.Editor";
            pEditor = m_application.FindExtensionByCLSID(pUID) as ESRI.ArcGIS.Editor.IEditor;
            if(pEditor.EditState == ESRI.ArcGIS.Editor.esriEditState.esriStateEditing )
                pEditor.StartOperation();
                GetAllPoitsInsidePolygon(pPolygonLayer.FeatureClass, pPointLayer.FeatureClass, ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum.esriSpatialRelContains, "TVSID");//TVSID is filed name whihc should be in the poly layer
                pEditor.StopOperation("PolygonDensity");
            else
              System.Windows.Forms.MessageBox.Show("Not in edit session");
        private void GetAllPoitsInsidePolygon(ESRI.ArcGIS.Geodatabase.IFeatureClass pFeatureClass1,ESRI.ArcGIS.Geodatabase.IFeatureClass pFeatClass2,ESRI.ArcGIS.Geodatabase.esriSpatialRelEnum lSpatialRel,String  strFeatFld)
              ESRI.ArcGIS.Geodatabase.IFeatureCursor pFeatCursor = pFeatureClass1.Search(null,false);
             int lFld=0;
            lFld = pFeatureClass1.FindField(strFeatFld);
                if(lFld == -1)
                    System.Windows.Forms.MessageBox.Show("field not found: " + strFeatFld);
                    return;
            ESRI.ArcGIS.Geodatabase.IFeature pFeature = pFeatCursor.NextFeature();
            while (pFeature != null)
                ESRI.ArcGIS.Geodatabase.ISpatialFilter pSpatialFilter = new ESRI.ArcGIS.Geodatabase.SpatialFilterClass();
                pSpatialFilter.Geometry = pFeature.ShapeCopy;
                pSpatialFilter.SpatialRel = lSpatialRel;
                pSpatialFilter.GeometryField = pFeatClass2.ShapeFieldName;
                pFeature.set_Value(lFld,pFeatClass2.FeatureCount(pSpatialFilter));
                System.Windows.Forms.MessageBox.Show("OID: " + pFeature.OID + ", count: " + pFeature.get_Value(lFld));
                pFeature.Store();
        #endregion
I hope this helps you....
Thanks and Regards,
Venkat Tammineni
JamalNUMAN
thank you for so much,
actually i need it to be written in VBA-Arcobjects not in any other language.
have you any idea how to do it in VBA-Arcobjects ?
where can i find examples of similar kind of work?
thank you
regards
Jamal
using System;
    /// <summary>
    /// </summary>
        [ComVisible(false)]
        [ComVisible(false)]
        /// <summary>
        /// </summary>
        /// <summary>
        /// </summary>
        #endregion
        #endregion
            try
        /// <summary>
        /// </summary>
            if (hook == null)
                return;
            else
        /// <summary>
        /// </summary>
            else
             int lFld=0;
                if(lFld == -1)
                    return;
                pFeature.Store();
        #endregion
Thanks and Regards,
Venkat Tammineni
Jamal Numan
thank you
regards
Jamal
please check below code...
Sub test()
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pPolyFLayer As IFeatureLayer
    Set pPolyFLayer = pMxDoc.FocusMap.Layer(1)
    Dim pPointFlayer As IFeatureLayer
    Set pPointFlayer = pMxDoc.FocusMap.Layer(0)
    Dim pEditor As IEditor, pUID As New UID
    Set pEditor = Application.FindExtensionByCLSID(pUID)
    If pEditor.EditState = esriStateEditing Then
        CountFeatures pPolyFLayer.FeatureClass, pPointFlayer.FeatureClass, _
                     esriSpatialRelContains, "NAME"
        pEditor.StopOperation "PolygonDensity"
    Else
        MsgBox "no edit session"
    End If
End Sub
Sub CountFeatures(pFC1 As IFeatureClass, _
                 pFC2 As IFeatureClass, _
                 lSpatialRel As esriSpatialRelEnum, _
                 strCountFld As String)
    Dim pFCur As IFeatureCursor
    Set pFCur = pFC1.Search(Nothing, False)
    Dim lFld As Long
    lFld = pFC1.FindField(strCountFld)
    If lFld = -1 Then
        MsgBox "field not found: " & strCountFld
        Exit Sub
    End If
    Dim pFeat As IFeature
    Set pFeat = pFCur.NextFeature
    Do While Not pFeat Is Nothing
        Dim pSF As ISpatialFilter
        Set pSF = New SpatialFilter
        Set pSF.Geometry = pFeat.ShapeCopy
        pSF.SpatialRel = lSpatialRel
        pSF.GeometryField = pFC2.ShapeFieldName
        pFeat.Value(lFld) = pFC2.FeatureCount(pSF)
        MsgBox "OID: " & pFeat.OID & ", count: " & pFeat.Value(lFld)
        pFeat.Store
    Loop
End Sub
is that your looking for ?...
Thanks and Regards,
Venkat
JamalNUMAN
Dear Venkat,
Thank you so much for the answer. It�??s really helpful
Sure. The code you have developed is working perfectly.
1. how to develop the code so that we don�??t need:
�?� To work in edit session.
�?� To have the field �??name�?� in the district layer.
2. How to develop the code considering the following approach:
�?� to intersect the two layers (districts and hospitals: both are polygons)
�?� And then to make summery in the table of the resultant layer (from the intersection) so that we count all the hospitals in each district.
I�??m supposed to print the result in the form and then to be able to export it to a table to excel
Please, see the attached file
Appreciated
Kalid
Sub test()
    Else
    End If
End Sub
    Dim lFld As Long
    If lFld = -1 Then
        Exit Sub
    End If
        pFeat.Store
    Loop
End Sub
Thanks and Regards,
Venkat
Jamal Numan
Dear Venkat,
Appreciated
Kalid
Whatever the code i have given is the intersect two poly and point layers and count the point within the polygon and add into polygon layer table ...and below is that thread where you can find the code for exporting into excel...Please change the code as per your requirement.
http://forums.esri.com/Thread.asp?c=93&f=992&t=227281&mc=6#msgid692161
vairaselvan
i need tat database can u send that
How to write a code VB �?? Arcobject that counts the number of points inside each polygon?
I�??ve two layers, point layer and polygon layer, I need to write a code that calculate the number of points inside each polygon
Thank you
kalid
