How to sort items in combobox?
4491
05-01-2013 11:54 AM
geomatic
Hi Everyone,
I want to ask spesific question about sorting items in combobox from A to Z. How can i perform sorting them?
If i cant sort them A to Z there is meaningless about the query that will be applied on it.
Waiting forward for your replies, kindly regards.
Tolga
Here are my vba codes:
Private Sub UserForm_Initialize()
Dim pMxDoc As IMxDocument
Dim pMap As IMap
Dim pFeatLayer As IFeatureLayer
Dim pFeatClass As IFeatureClass
Dim pFields As IFields
Dim pField As IField
Dim i As Integer
Set pMxDoc = ThisDocument
Set pMap = pMxDoc.FocusMap
Set pFeatLayer = pMap.Layer(0)
Set pFeatClass = pFeatLayer.FeatureClass
Set pFields = pFeatClass.Fields
For i = 0 To pFields.FieldCount - 1
cboMusteri.AddItem pFields.Field(i).Name
Dim pLayer As ILayer
Set pLayer = pMap.Layer(0)
Set pFeatLayer = pLayer
Dim pFeature As IFeature
Dim pFeatCursor As IFeatureCursor
Dim pQueryFilter As IQueryFilter
Set pQueryFilter = New QueryFilter
pQueryFilter.SubFields = "MALIK"
Set pFeatCursor = pFeatLayer.Search(pQueryFilter, True)
Set pFeature = pFeatCursor.NextFeature
Dim j As Integer
Dim cDuplicate As Boolean
cDuplicate = False
cboMusteri.Clear
Do While Not pFeature Is Nothing
For j = 0 To cboMusteri.ListCount - 1
cDuplicate = False
If cboMusteri.List(j) = pFeature.Value(pFeature.Fields.FindField("MALIK")) & "" Then
cDuplicate = True
End If
Next j
If cDuplicate = False Then
cboMusteri.AddItem pFeature.Value(pFeature.Fields.FindField("MALIK")) & ""
End If
Loop
Set pFeatCursor = Nothing
Set pFeature = Nothing
Set pFeatLayer = Nothing
Set pLayer = Nothing
Set pMap = Nothing
Set pMxDoc = Nothing
End Sub
LanceShipman
JimMeuse
Maybe try something like this:
pQueryFilterDefinition.PostfixClause = "ORDER BY Town"
using IQueryFilterDefinition2 interface.
DuncanHornby
MVP Notable Contributor
Jim's solution is good but it does not work with all data formats (i.e. Shapefiles) see this thread.
TomaCasa
just throw them into a list of strings first?
I use c# to code in, but its pretty simple in both languages.
using system.Collections.Generic;
List<String> cblist = new List<String>();
cblist.Items.Add(Value);
cblist.Sort();
then you can either bind the list to the Combo box, or manually add them in by looping 🙂
Tomas.
