How to set a response object with my polylines?
972
10-21-2013 05:43 AM
MichaelEber
I  have a geo service that seems to finally be working. I have the service setup with a list of Polylines as the returned object. This is what I'm trying to implement but it doesn't work:
 IPointCollection points = new MultipointClass();
 points.AddPoint(station);
 points.AddPoint(targets[index]);
 messages.AddMessage(string.Format("Computing distance from origin to target {0}", index));
 Polyline result = distanceComputer.CostPathAsPolyline(points,
     hydrographyRasterDataset,
     hydrographyRasterDataset) as Polyline;
 IGeometry feature = result as IGeometry;
 messages.AddMessage("Getting new row for output.");
 IFeatureBuffer buffer = outputClass.CreateFeatureBuffer();
 IFeature polyline = (IFeature) buffer;
 messages.AddMessage("adding shape");
 polyline.Shape = feature;
 messages.AddMessage("adding object");
 polyline.set_Value(polyline.Fields.FindField("SHAPE"), result);
 messages.AddMessage("adding length");
 polyline.set_Value(polyline.Fields.FindField("SHAPE_Length"), ((IPolyline)result).Length);
 messages.AddMessage("Commiting to output");
 outputCursor.InsertFeature(buffer);
When I try setting the value for "SHAPE" I get an exception and the message is:
This spatial reference object cannot be defined from the available information
So how exactly to I set the polyline in the return object (basically adding rows of Polylines to the OutputFeatureSet) so that it does not blow up?
NeilClemmons
Honored Contributor
You're setting the Shape field value here:
This is not the correct way to set the Shape field (the above line was correct) and you don't need to do it twice:
You can't set the Shape.Length field value.  It is read-only and is managed by the geodatabase.  It will update when you update the Shape field.
MichaelEber
I added more debugging to the code and found that when I get the IGeometryCollection back from CostPathAsPolyline then cast it to Polyline, the resulting object is null!!!???  How do I go from an IGeometryCollection to a Polyline correctly?
