How to Select Feature by XY Location and Highlight it in ArcMap 9.3 programmatically?
6910
12
05-18-2011 12:46 AM
dgesridgesri
Greetings,
I hope to find a solution to the following questions that I really need in my project:
  1. How to find the feature under the mouse click (XY Coodinates) from a feature layer in ArcMap 9.3?
  2. How to highlight (flash) a selected feature in ArcMap 9.3 using VB.Net?
Please advise....
imranmd
hi frnd iam new to programming ..
i want to show a pop up window to display the element attributes (same as map identify tool) .
can anyone suggest some ideas
here is my code for displaying the map in wpf.
using System;
using System.Windows;
using System.Windows.Forms;
using System.Drawing;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Controls;
using ESRI.ArcGIS.CadastralUI;
using ESRI.ArcGIS.ParcelFabricTools;
using ESRI.ArcGIS.ADF;
using ESRI.ArcGIS.Editor;
using ESRI.ArcGIS.EditorExt;
using ESRI.ArcGIS.Geodatabase;
using ESRI.ArcGIS.ArcMapUI;
using ESRI.ArcGIS.Geometry;
using ESRI.ArcGIS.Display;
using System.Runtime.InteropServices;
namespace MapHostedInWPF
    public partial class Window1 : Window
        AxMapControl mapControl;
        AxToolbarControl toolbarControl;
        AxTOCControl tocControl;
        public Window1()
            InitializeComponent();
            CreateMapControl();
        private void CreateMapControl()
            mapControl = new AxMapControl();
            mapHost.Child = mapControl;
            toolbarControl = new AxToolbarControl();
            toolbarHost.Child = toolbarControl;
            tocControl = new AxTOCControl();
            tocHost.Child = tocControl;
        private void SetMapProperties()
            mapControl.Dock = DockStyle.None;
            mapControl.BackColor = Color.FromArgb(233, 233, 233);
        private void WireMapEvents()
            mapControl.OnMouseMove += new IMapControlEvents2_Ax_OnMouseMoveEventHandler
                (mapControl_OnMouseMove);
        private void mapControl_OnMouseMove(object sender,
            IMapControlEvents2_OnMouseMoveEvent e)
            System.Console.WriteLine(e.mapX.ToString());
        private void Window_Loaded(object sender, RoutedEventArgs e)
            try
                SetMapProperties();
                WireMapEvents();
                mapControl.LoadMxFile("D:\\California\\California.mxd");
                tocControl.SetBuddyControl(mapControl);
                toolbarControl.SetBuddyControl(mapControl);
                toolbarControl.AddItem("esriControls.ControlsOpenDocCommand");
                toolbarControl.AddItem("esriControls.ControlsAddDataCommand");
                toolbarControl.AddItem("esriControls.ControlsSaveAsDocCommand");
                toolbarControl.AddItem("esriControls.ControlsMapNavigationToolbar");
                toolbarControl.AddItem("esriControls.ControlsEditingToolbar");
                toolbarControl.BackColor = Color.FromArgb(245, 245, 220);
            catch (Exception ex)
                System.Windows.MessageBox.Show(ex.Message);
imranmd
can you please tell me the code to implement yours code in my project...
public void WorkIdentify()
           IMxDocument doc =  ArcMap.Application.Document as IMxDocument;
            IActiveView activeView = doc.ActiveView;
            IPoint mouseLocation = GetScreenCoordinatesFromMapCoorindates(doc.CurrentLocation, activeView);
            System.Int32 x = (System.Int32) mouseLocation.X;
            System.Int32 y = (System.Int32) mouseLocation.Y;
            if (activeView == null)
                return;
            ESRI.ArcGIS.Carto.IMap map = activeView.FocusMap;
            ESRI.ArcGIS.CartoUI.IIdentifyDialog identifyDialog = new ESRI.ArcGIS.CartoUI.IdentifyDialogClass();
            identifyDialog.Map = map;
            //Clear the dialog on each mouse click
            identifyDialog.ClearLayers();
            ESRI.ArcGIS.Display.IScreenDisplay screenDisplay = activeView.ScreenDisplay;
            ESRI.ArcGIS.Display.IDisplay display = screenDisplay; // Implicit Cast
            identifyDialog.Display = display;
            ESRI.ArcGIS.CartoUI.IIdentifyDialogProps identifyDialogProps = (ESRI.ArcGIS.CartoUI.IIdentifyDialogProps)identifyDialog; // Explicit Cast
            ESRI.ArcGIS.Carto.IEnumLayer enumLayer = identifyDialogProps.Layers;
            enumLayer.Reset();
            ESRI.ArcGIS.Carto.ILayer layer = enumLayer.Next();
            while (!(layer == null))
                identifyDialog.AddLayerIdentifyPoint(layer, x, y);
            identifyDialog.Show();
imranmd
Dear Sandhya Yamarthi,
Can you please tell me how to call the following code...
namespace Project1
class Class1
[DllImport("kernel32.dll")]
static extern void Sleep(uint dwMilliseconds);
public void FlashFeature(IFeature Feature, IMxDocument MxDoc)
try
MxDoc.ActiveView.ScreenDisplay.StartDrawing(0, (short)(esriScreenCache.esriNoScreenCache));
switch (Feature.Shape.GeometryType)
case (esriGeometryType.esriGeometryPolyline):
FlashLine(MxDoc.ActiveView.ScreenDisplay, Feature.Shape);
break;
case (esriGeometryType.esriGeometryPolygon):
FlashPolygon(MxDoc.ActiveView.ScreenDisplay, Feature.Shape);
break;
case (esriGeometryType.esriGeometryPoint):
FlashPoint(MxDoc.ActiveView.ScreenDisplay, Feature.Shape);
break;
MxDoc.ActiveView.ScreenDisplay.FinishDrawing();
catch (Exception Err)
MessageBox.Show("Error : " + Err.Message);
public void FlashLine(IScreenDisplay Display, IGeometry Geometry)
ISimpleLineSymbol LineSymbol;
ISymbol Symbol;
IRgbColor RgbColor;
try
LineSymbol = new SimpleLineSymbolClass();
LineSymbol.Width = 4;
RgbColor = new RgbColorClass();
RgbColor.Green = 128;
Symbol = (ISymbol)LineSymbol;
Symbol.ROP2 = esriRasterOpCode.esriROPNotXOrPen;
Display.SetSymbol((ISymbol)(LineSymbol));
Display.DrawPolyline(Geometry);
Sleep(300);
LogFile.WriteLog("Error at : " + Err.Message);
public void FlashPolygon(IScreenDisplay Display, IGeometry Geometry)
ISimpleFillSymbol FillSymbol;
ISymbol Symbol;
IRgbColor RgbColor;
try
FillSymbol = new SimpleFillSymbolClass();
FillSymbol.Outline = null;
Symbol = (ISymbol)FillSymbol;
Display.SetSymbol((ISymbol)(FillSymbol));
Display.DrawPolygon(Geometry);
Sleep(300);
public void FlashPoint(IScreenDisplay Display, IGeometry Geometry)
ISimpleMarkerSymbol MarkerSymbol;
ISymbol Symbol;
IRgbColor RgbColor;
try
MarkerSymbol = new SimpleMarkerSymbolClass();
MarkerSymbol.Style = esriSimpleMarkerStyle.esriSMSCircle;
Symbol = (ISymbol)MarkerSymbol;
Display.SetSymbol((ISymbol)MarkerSymbol);
Display.DrawPoint(Geometry);
Sleep(300);
LogFile.WriteLog("Error : " + Err.Message);
I have already post my code..
Thanks for your valuable time and consideration...
Waiting for your reply..
