How to make programmatically split polyline at many points (not at one point)
5990
05-12-2012 11:23 PM
MarkMindlin
Hi there,
I am searching a method that can do a split polyline at many points. (originally make split at polygon(s) intersect polyline(s)).
I though that IFeatureEdit2.Split() or IFeatureEdit2.SplitWithUpdate() can manage with it. Instead these two methods have argument like IGeometry  - after I take as a parameter IGeometry (Multipoint) - I get an error "Splitting a polyline requires a point splitter." (meaning must be IPoint).
Any suggestion, please. I look forward to hearing about ArcObjects, not workaround.
MarkMindlin
May be an interface IPolycurve2 could be usable. It has a SplitAtPoints method.
KenBuja
MVP Esteemed Contributor
Here's how I split a polyline using points.
Private Sub SplitFeature(ByRef pfeature As ESRI.ArcGIS.Geodatabase.IFeature, ByRef pSplitPoints As ESRI.ArcGIS.Geometry.IPointCollection)
    Dim pEnumVertex As ESRI.ArcGIS.Geometry.IEnumVertex
    Dim pPolyCurve As ESRI.ArcGIS.Geometry.IPolycurve2
    Dim pEnumSplitPoint As ESRI.ArcGIS.Geometry.IEnumSplitPoint
    pEnumVertex = pSplitPoints.EnumVertices
    pPolyCurve = pfeature.Shape
    pEnumSplitPoint = pPolyCurve.SplitAtPoints(pEnumVertex, True, True, -1)
    'You can check to see if the line was actually split if you need to do more things with the resultant polylines.
    'If Not pEnumSplitPoint.SplitHappened Then Exit Sub
End Sub
MarkMindlin
Thank you Ken,
Could you provide a suggestion how can I get new parts of the feature after split? Meaning pointers to the new polylines.
KenBuja
Sure. Here's one way to do it in an edit session as an Add-in. And don't forget to mark the question as answered.
  Private pEditLayers As ESRI.ArcGIS.Editor.IEditLayers = My.ArcMap.Editor
  Private pEditor As ESRI.ArcGIS.Editor.IEditor  = My.ArcMap.Editor
    Dim pGeoColl As ESRI.ArcGIS.Geometry.IGeometryCollection
    Dim pNewFeature As ESRI.ArcGIS.Geodatabase.IFeature
    Try
      pfeature.Shape.Project(pEditor.Map.SpatialReference)
      pGeoColl = pPolyCurve
      pfeature.Shape = BuildPolyline(pGeoColl.Geometry(0))
      pfeature.Store()
      For i As Integer = 1 To pGeoColl.GeometryCount - 1
        pNewFeature = pEditLayers.CurrentLayer.FeatureClass.CreateFeature
        pNewFeature.Shape = BuildPolyline(pGeoColl.Geometry(i))
        CopyAttributes(pfeature, pNewFeature)
        pNewFeature.Store()
    Catch ex As Exception
      System.Windows.Forms.MessageBox.Show(ex.ToString, "SplitLine: SplitFeatures")
    End Try
  End Sub
  Private Function BuildPolyline(ByRef pSegColl As ESRI.ArcGIS.Geometry.ISegmentCollection) As ESRI.ArcGIS.Geometry.IPolyline
    Dim pPolyline As ESRI.ArcGIS.Geometry.IGeometryCollection = New ESRI.ArcGIS.Geometry.Polyline
    Dim pGeometry As ESRI.ArcGIS.Geometry.IGeometry
    Try
      pGeometry = pPolyline
      pGeometry.SpatialReference = pEditor.Map.SpatialReference
      pPolyline.AddGeometries(1, pSegColl)
      Return pPolyline
      System.Windows.Forms.MessageBox.Show(ex.ToString, "SplitLine: BuildPolyline")
      Return Nothing
    End Try
  End Function
  Private Sub CopyAttributes(ByRef pInFeature As ESRI.ArcGIS.Geodatabase.IFeature, ByRef pOutFeature As ESRI.ArcGIS.Geodatabase.IFeature)
    Dim pField As ESRI.ArcGIS.Geodatabase.IField
    Dim pFields As ESRI.ArcGIS.Geodatabase.IFields
    Try
      pFields = pInFeature.Fields
      For i As Integer = 0 To pFields.FieldCount - 1
        pField = pFields.Field(i)
        If pField.Editable Then
          If Not pField.Type = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeOID And Not pField.Type = ESRI.ArcGIS.Geodatabase.esriFieldType.esriFieldTypeGeometry Then
            pOutFeature.Value(i) = pInFeature.Value(i)
          End If
        End If
      System.Windows.Forms.MessageBox.Show(ex.ToString, "SplitLine: CopyAttributes")
    End Try
  End Sub
MarkMindlin
Thank you a lot, Ken!
