How to load a raster back into a raster dataset without file I/O?
3225
01-30-2014 05:45 AM
MichaelEber
I have this fairly complex routine running as a service.  All was well right up until I called one of the methods and instead of returning a RasterDataset as an IGeoDataset it returned an IRaster as the IGeoDataset.  I need a consistent way of passing this modified raster throughout the code and I was using a RasterDataset for doing that.  But no matter what I do I cannot get that modified raster into the dataset without (apparently) saving it to disk.  I want to avoid this since File I/O on a service is evil.  And ESRI doesn't have modern software so it does not take a stream as input for loads preventing me from using a memory stream.
So any suggestions on how to load the modified raster back into the RasterDataset without saving to disk?
ErinBrimhall
Have you looked at the SaveAsRasterDataset method off the ISaveAs2 interface?
Also, the IRaster2 interface has a RasterDataset property, which might be what you're looking for.
ErinBrimhall
MichaelEber
I was trying to avoid doing any saving.  Typically, in a normal server environment, doing a file write causes a lock on the mutex which momentarily halts all services running on the server.
But the IRaster2 interface looks like it is just what I was looking for....assuming that RasterDataset isn't null.  🙂
Thank you!
