How to implement "select by location" by VBA and ArcObject ?
2230
6
02-06-2011 11:42 PM
GarySham
Dear all,
I have two polygon feature classes, polygon A and polygon B.
I would like to write a VBA to perform a select by location function to find out which polygon(s) in polygon B is/are intersect with a selected polygon in polygon A which is selected by a user.
I know, I can use "ISpatialFilter" to do this, but don't know how to implement it in VBA. Would you mind provide some sample code/hints for me ?
Regards
Gary
Venkata_RaoTammineni
Dear all,
Regards
Gary
public IFeatureCursor GetStreetsInEnvelope(IFeatureClass featureClass)
// Create the envelope and define its position.
  IEnvelope envelope = new EnvelopeClass();  envelope.PutCoords(-84.4078, 33.7787, -84.3856, 33.7997);
  // Create the spatial filter and set its spatial constraints.
  ISpatialFilter spatialFilter = new SpatialFilterClass();
  spatialFilter.Geometry = envelope;
  spatialFilter.GeometryField = featureClass.ShapeFieldName;
spatialFilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects;
  // Set the attribute constraints and subfields.
// We want to exclude ramps, highways and interstates.
spatialFilter.WhereClause = "NAME <> 'Ramp' AND PRE_TYPE NOT IN ('Hwy', 'I')";    spatialFilter.SubFields = "NAME, TYPE";
// Execute the query.
  IFeatureCursor featureCursor = featureClass.Search(spatialFilter, true);
  return featureCursor;
GarySham
Actually, I have two polygon feature classes (RoadPolygon and AsstPolygon). The user selects a RoadPolygon and my code can find out all AsstPolygon which intersect with the selected RoadPolygon. I already write some code in VBA but seem does not work, anyone can help ?
' Find out the correct layer of RoadPolygon and AsstPolygon
For i = 0 To (pMap.LayerCount - 1)
    If pMap.Layer(i).Name = "RoadPolygon" Then
        Set RoadLayer = pMap.Layer(i)
    End If
    If pMap.Layer(i).Name = "RoadAssetPolygon" Then
        Set AssetLayer = pMap.Layer(i)
    End If
Next i
' Build a spatial filter
Dim spatialFilter As ISpatialFilter
Set spatialFilter = New spatialFilter
With spatialFilter
'      Set .Geometry = pMap.FeatureSelection ? ,pPointCollection ?, pFeature  'I don't know
      .GeometryField = AsstLayer
      .SpatialRel = esriSpatialRelIntersects
    End With
Dim featureSelection As IFeatureSelection
Set featureSelection = AsstLayer
featureSelection.SelectFeatures spatialFilter, esriSelectionResultNew, False
pDoc.ActiveView.Refresh
'Dim featureSelection As IFeatureSelection
'Set featureSelection = AsstLayer
'featureSelection.SelectFeatures spatialFilter, esriSelectionResultNew, False
'pDoc.ActiveView.Refresh
SteveFang
Your spatial filter is not set up properly.  You need three pieces of information.
Geometry - the shape of the selected RoadPolygon feature
GeometryField - the name of the shape field in your RoadPolygon, usually "SHAPE"
SpatialRel - whatever you have in your code
Try that and see if it works...
Steve
GarySham
Thank You so much
Now I can select the AssetPolygon. However I am fail to refreah the map in order to show which AssetPolygon(s) is/are selected by the spatialFilter, any can help ?
My code is as follew :
Set pAssetFeatureClass = pAssetLayer.FeatureClass
    Set pSpatialFilter.Geometry = pFeature.Shape
    pSpatialFilter.SpatialRel = esriSpatialRelIntersects
    Set pFeature = pEnumFeat.Next
    Set pAssetFeatureCursor = pAssetFeatureClass.Search(pSpatialFilter, Flase)
    Set pAssetFeature = pAssetFeatureCursor.NextFeature
    Do Until pAssetFeature Is Nothing
     NumOfAsset = NumOfAsset + 1
   Loop
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim pActiveView As IActiveView
Set pActiveView = pMap
pActiveView.Refresh ---------- It does not seem work !!!!!
SteveFang
Look at IFeatureSelection interface in the documentations.  There are sample code that your can use.  Basically, you want to make your selection in your featurelayer and trigger the SelectionChanged method in IFeatureSelection.
KingsleyPayne
Sub SpatialFilter()
Dim pMxd As IMxDocument
Set pMxd = ThisDocument
Dim pEnumFeature As IEnumFeature
Set pEnumFeature = pMxd.FocusMap.FeatureSelection
pEnumFeature.Reset
Dim pSearchFeature As IFeature
Set pSearchFeature = pEnumFeature.Next
If (pSearchFeature Is Nothing) Then
    MsgBox "Please select a feature to search."
    Exit Sub
End If
pMxd.FocusMap.ClearSelection
Dim pLayer As ILayer
Dim pSearchLayer As IFeatureLayer
Dim pFeatureLayer As IFeatureLayer
Dim i As Integer
For i = 0 To pMxd.FocusMap.LayerCount - 1
    Set pLayer = pMxd.FocusMap.Layer(i)
    If pLayer.Name = "Roads" Then
        Set pSearchLayer = pLayer
        Exit For
    End If
If (pSearchLayer Is Nothing) Then
    MsgBox "Roads layer not found!"
    Exit Sub
End If
    If pLayer.Name = "Road Assets" Then
        Set pFeatureLayer = pLayer
        Exit For
    End If
    MsgBox "Road Assets layer not found!"
    Exit Sub
End If
Dim pSpatialFilter As ISpatialFilter
Set pSpatialFilter = New SpatialFilter
Dim pTopoOp As ITopologicalOperator
Set pTopoOp = pSearchFeature.Shape
' You might need to buffer the search geometry in certain cases.
' Use a buffer value of 0 to search using the original geometry.
Dim pSearchGeometry As IGeometry
Set pSearchGeometry = pTopoOp.Buffer(10)
Set pSpatialFilter.Geometry = pSearchGeometry
pSpatialFilter.GeometryField = pSearchLayer.FeatureClass.ShapeFieldName
Dim pFeatureCursor As IFeatureCursor
Set pFeatureCursor = pFeatureLayer.Search(pSpatialFilter, False)
Dim pFeature As IFeature
Dim FeatureCount As Integer
Set pFeature = pFeatureCursor.NextFeature
Do While Not pFeature Is Nothing
    FeatureCount = FeatureCount + 1
    pMxd.FocusMap.SelectFeature pFeatureLayer, pFeature
Loop
If (FeatureCount = 1) Then
    MsgBox FeatureCount & " feature found."
Else
    MsgBox FeatureCount & " features found."
End If
Set pActiveView = pMxd.FocusMap
pActiveView.Refresh
End Sub
