how to get the value of IField ????
5522
13
07-09-2010 06:39 AM
AbdulrahmanAlqasim
i want to get the field value of a feature class using this code:
pFeature = pFeatureCursor.NextFeature();
pField = pFeature.Fields.get_Field(0);
how i can get the value of pField.
thank you
JamesCrandall
You could just get the value right from pFeature:
Dim value as String
Do Until pFeature Is Nothing
  value = pFeature.Value(pFeature.Fields.FindField("TheFieldName"))
Loop
AbdulrahmanAlqasim
thanks man
that was very helpful
JamesCrandall
No problem -- glad I could help.
pavankalvala
I am able to get the value of a field name "FID" in a message box. I am trying to put this value into a word doc Bookmark.
How can I do this. Any  help.
Code I used to get the field value of "FID":
M = pFeat.Value(pFeat.Fields.FindField("FID"))
            pFeat = pEnumFeat.Next
            MsgBox(M)  /// I need this value shown in message box pulled into a word doc bookmark.
pavankalvala
Is there a code to loop through the field names from a selected feature?
AlexanderGray
Honored Contributor
If you just want to loop through all the values you could do something like this
feature = get feature with the method of your choice
i = 0
for i to feature.fields.count -1
  theValue = feature.value(i)
  theFieldName = feature.fields.field(i)
Of course you have to be careful the way you handle the field values, you will be getting objectids, shapes, integers, strings and probably dbnulls.
Cheers
pavankalvala
I am able to get the field name through the loop as below:
pEnumFeat = pMxdoc.FocusMap.FeatureSelection
        ' loop through each field and add the field name to a list
        For ii = 0 To fields.FieldCount - 1
            Field = fields.Field(ii)
            fieldname = Field.Name
            fieldvalue = Field.VarType
            ' fieldvalue = pFeat.Value(pFeat.Fields.Field)       '' trying to get the field value
            'value = Field.DefaultValue                               '' trying to get the field value
            namelist = namelist & fieldname & fieldvalue & Chr(13)
MsgBox(namelist, , "field names")
This displays all the fields from the selected feature. How do I get the field value from the above loop.
AlexanderGray
Honored Contributor
fieldvalue = pFeat.Value(ii)
pavankalvala
I tried that, but I get an error ' conversion from type '_ComObject' to type 'Long' is not valid'
I set the value as :
Dim value as long.  ( I tried using 'string', 'double', 'long' and I get the same error as above)
Any hint?
