How to get IFeatureLayer from using Geoprocessor and SelectLayerByLocation
2795
06-26-2013 07:40 PM
MarkMindlin
Hi there!
I would appreciate if anybody can tell please
if it possible (and how(please provide a code))
some pseudo code here
Geoprocessor gp = new Geoprocessor();
IFeatureClass pCurrentFeatureClass = // some code to OpenFeatureClass
MakeFeatureLayer makeFeatureLayer = new MakeFeatureLayer();
makeFeatureLayer.in_features = pCurrentFeatureClass;
makeFeatureLayer.out_layer = "CurrentFeatureLayer";
SelectLayerByLocation selectLayerByLocation = new SelectLayerByLocation();
selectLayerByLocation.in_layer = "CurrentFeatureLayer";
gp.Execute(selectLayerByLocation,null);
HERE: HOW TO GET IFeatureLayer? // in order to get ISelectionSet in the "pCurrentFeatureClass" after SelectLayerByLocation
Please do not provide solutions with GP.CopyFeatures, mainly because I need to save ObjectID from the pCurrentFeatureClass.
Please do not provide ArcObjects solutions with IQueryFilter.
YairSegal
Try the following solution:
Geoprocessor GP = new Geoprocessor();
makeFeatureLayer.in_features = @"C:\temp.gdb\in_feature_class";
makeFeatureLayer.out_layer = "out_feature_layer_name";
GP.Execute(makeFeatureLayer, null);
selectLayerByLocation.in_layer = "out_feature_layer_name";
IGeoProcessorResult resultSelection = GP.Execute(selectLayerByLocation, null) as IGeoProcessorResult;
IGPUtilities gpUtils = new GPUtilitiesClass();
IFeatureLayer myFeatureLayer = gpUtils.DecodeLayer(resultSelection.GetOutput(0)) as IFeatureLayer;
KenBuja
MVP Esteemed Contributor
Here's how I return a feature class from a geoprocessing process. This example uses the geoprocessing tool "CreateFeatureClass". You can also return a feature layer from the function ReturnObjectfromResult.
    Friend Function CreateFeatureClass(ByVal FCLocation As String, ByVal FCName As String, ByVal pSR As ESRI.ArcGIS.Geometry.ISpatialReference3, ByVal GeometryType As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass
        Dim CreateFClass As New ESRI.ArcGIS.DataManagementTools.CreateFeatureclass
        Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            Using releaser As New ESRI.ArcGIS.ADF.ComReleaser
                releaser.ManageLifetime(CreateFClass)
                CreateFClass.out_path = FCLocation
                CreateFClass.out_name = FCName
                CreateFClass.spatial_reference = pSR
                CreateFClass.geometry_type = GeometryType
                Result = RunTool(CreateFClass, Nothing, True)
                If Result Is Nothing Then Return Nothing
                Return ReturnObjectfromResult(Result, "Feature Class")
            End Using
        Catch ex As Exception
            System.Windows.Forms.MessageBox.Show(ex.ToString & vbNewLine & ex.StackTrace.ToString, "Create Feature Class")
            Return Nothing
        End Try
    End Function
    Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2, Optional ByVal AddOutput As Boolean = False) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2
        Try
            System.Windows.Forms.Cursor.Current = Windows.Forms.Cursors.WaitCursor
            Dim GP As New ESRI.ArcGIS.Geoprocessor.Geoprocessor
            GP.AddOutputsToMap = AddOutput
            GP.OverwriteOutput = True
            Result = CType(GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2)
            If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error")
            GP.ClearMessages()
            ReturnMessages(Result, "Fail")
            System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor")
        End Try
        Return Result
    End Function
    Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String)
        If pResult Is Nothing Then Exit Sub
        Dim ErrorMessage As String
        If pResult.MessageCount > 0 Then
            For Count As Integer = 0 To pResult.MessageCount - 1
                ErrorMessage += pResult.GetMessage(Count)
        End If
        System.Windows.Forms.MessageBox.Show(ErrorMessage, Title)
    End Sub
   Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object
        Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue
        Dim InMemFC As String
        Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities
        Try
            GPVal = result.GetOutput(0)
            InMemFC = GPVal.GetAsText()
            Select Case Type
                Case "Feature Class"
                    Return GPUtil.OpenFeatureClassFromString(InMemFC)
                Case "Table"
                    Return GPUtil.OpenTableFromString(InMemFC)
                Case "Feature Layer"
                    Return GPUtil.OpenFeatureLayerFromString(InMemFC)
                Case Else
                    Return Nothing
            End Select
            System.Windows.Forms.MessageBox.Show(ex.ToString, "ReturnObjectfromResult error")
            Return Nothing
        End Try
    End Function
