How to connect to SDE geodatabase without sde service
2614
04-13-2011 06:57 AM
DeminHu
I have a simple question, how to connect to sde geodatabase which doesn't have a sde service ( how to set instance property)? Should use the connection file ? if using connection file working, besdes this method,is there any other way ( how to set propertyset about instance)?
Thank you very much.
