How to cast a FeatureClass?
3329
12-02-2014 07:26 AM
ShaningYu
Honored Contributor
I need to cast a featureclass to IPolyline.  In this piece of code below
IFeatureClass fcR = gHelp.GetFeatureClass(pWS2, fNameR);
ESRI.ArcGIS.Geometry.IPolyline refLine = fcR as ESRI.ArcGIS.Geometry.IPolyline;
the IPolyline refLine is null.  What's wrong in this piece of code?  Thanks if you can help.
Tags (1)
ShaningYu
Honored Contributor
I found my mistake in my post.  The correct way is to cast a line feature of a featureclass as an IPolyline:
ESRI.ArcGIS.Geometry.IPolyline pLine = (ESRI.ArcGIS.Geometry.IPolyline)feature.ShapeCopy;
Thanks for your review.
FreddieGibson
Honored Contributor
Hi Shuping,
You are correct in your findings. You cannot cast a FeatureClass to IPolyline because a feature class is a collection of polyline. As you discovered, you'd first need to get a feature (IFeature) from the polyline feature class and then you could cast its shape to IPolyline.
