How to Bind application developed using ArcEngine v10 to work on ArcGIS Desktop v9.3
925
02-25-2011 05:17 AM
AlekhyaDatta
Using the below mentioned source code, I am able to bind the Runtime for ArcGIS 10, but if I want to deploy the same application on other system having ArcGIS Desktop License 9.3, I am unable to do the same. Can anyone please guide me how to bind 9.3 environment in below mentioned code:
using System;
using System.Collections.Generic;
using System.Windows.Forms;
using ESRI.ArcGIS;
namespace Controls
    static class Program
        /// <summary>
        /// The main entry point for the application.
        /// </summary>
        [STAThread]
        static void Main()
            Application.EnableVisualStyles();
            Application.SetCompatibleTextRenderingDefault(false);
            if (!RuntimeManager.Bind(ProductCode.Engine))
                if (!RuntimeManager.Bind(ProductCode.Desktop))
                    MessageBox.Show("Unable to bind to ArcGIS runtime. Application will be shut down.");
                    return;
            Application.Run(new My_Tool.frmLogin());
Is there any other way using which I can run application developed using Engine 10 into previous versioned license...
Thanks in Advance!!!
Regards,
Er. Alekhya Datta [WTI-ATL (TCS, Chennai)].
NeilClemmons
Honored Contributor
You can't.  ArcObjects are not backwards compatible.  Your application can only run on machines that have the same version you compiled against (or higher in most cases).
