How to access ArcSDE geodatabase as IWorkspace from GeoData Service using ArcObjects JAVA?
825
01-04-2017 02:54 AM
Vara_PrasadM_S
Could someone please tell me how to access ArcSDE Geodatabase, which is published as GeoData service, into IWorkspace interface using ArcObjects.
I am trying to initialize IGeoDataServer as below and then trying to cast this object to instantiate IGeoDataServerObjects interface and then call IGeoDataServerObjects::getDefaultWorkingWorkspace() to get object of IWorkspace.
static IGeoDataServer initGeoDataServerFromInternetServer(String url, String
    serviceName)throws Exception{
    // Create a property set for connection properties.
    IPropertySet propertySet = new PropertySet();
    propertySet.setProperty("URL", url);
    // Connect to the server and get an enumerator for its objects.
    IAGSServerConnectionFactory agsServerConnectionFactory = new
        AGSServerConnectionFactory();
    IAGSServerConnection agsServerConnection = agsServerConnectionFactory.open
        (propertySet, 0);
    IAGSEnumServerObjectName enumServerObjectName =
        agsServerConnection.getServerObjectNames();
    enumServerObjectName.reset();
    // Iterate through the objects to locate the geodata service.
    IAGSServerObjectName serverObjectName = null;
    IGeoDataServer geoDataServer = null;
    while ((serverObjectName = enumServerObjectName.next()) != null){
        if (serverObjectName.getName().equals(serviceName)){
            IName name = (IName)serverObjectName;
            geoDataServer = (IGeoDataServer)name.open();
            break;
    return geoDataServer;
However, unable to cast object of IGeoDataServer neither to GeoDataServer nor IGeoDataServerObjects interface.
Please let me know if I am not clear anywhere.
Thanks &Regards,
Vara Prasad.
