How is possible to publish in AGS a custom toolbox implemented with IGPFunction2?
3676
5
03-10-2011 05:49 AM
Víctor_M_Bajo_Pérez
I've implemented a custom tool for toolbox with IGPFunction2 and IGPFunctionFactory.
I've read the basics in http://resources.esri.com/help/9.3/arcgisengine/dotnet/e7d06ae9-a6d1-4248-a7a3-9d5f375f088c.htm.
Since It has unsupported parameters, as explained here: http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geoprocessing/an_ove-2102662086.htm , I had did "Using the string representation" in a model and then I had published it.
I've used examples like "creating a non-trivial" custom GP tool" and "Calculate Area", using ModelBuilder if it has been necessary.
In all case, absolutly in all case, i've obtained this messages:
On publishing: Configuration ServerGPObject.GPServer is not found - in Server Configuration - as warning.
On using: ERROR 000816: The tool is not valid. in ServerGPObject.GPServerSync - as error.
I've read this in 9.3.1, written in aug 2010, http://forums.arcgis.com/threads/16614-Add-Custom-GP-Tool-to-Toolbox?highlight=implementing+custom+t...
which goes back historically to feb 2009 in http://forums.esri.com/thread.asp?t=274589&f=1170&c=93.
Consequently, what is required to publish with ArcGIS Server a custom tool in ArcToolbox and the examples given are forgetting? for example, "extends server object"? as http://edndoc.esri.com/arcobjects/9.2/NET_Server_Doc/developer/ArcGIS/ArcObjects/extend_ags_extensio... , with options "[AutomationProxy(true), ClassInterface(ClassInterfaceType.AutoDual)]". Is itdocumented?, for example, where write automationProxy and AutoDual?.
What needs to be done so that a tool can be published on AGS?.
It is really possible to publish a custom tool for toolbox or only it's possible to publish custom models and custom scripts?. Aparently, documentation from ESRI only explains this case with models and scripts.
Developement environment:
XP SP 3 Prof Ed.
ArcGIS Server & Desktop 9.3.1
VS 2008.
Framework .NET 3.5
Thanks in advance and best regards.
BryanGunter
Having the same issue.  Have a written custom geoprocessor that is configured to work in desktop using esriregasm tool.
The tool is inside of an mxd.
i deploy the tool to arcserver using Arcserver manager and create a geoprocessing service.
  I get the error that the "parameters need repair".  when i go back to the tool in desktop the one in the mxd no parameters exist anymore.  However i can reload the tool from catalog and all the parameters still exist.
The tool works fine in desktop just not as a service.
Anyone find a solution to this issue?
Bryan
TruongPham
Dear Víctor M. Bajo Pérez
I have same problem which what you had. Are you solve your problem?
Best regards,
Truong Pham
DeonaEvans
Same problem.....
zengzhe
step 1:"Registering the DLL" to Desktop;
"C:\Program Files (x86)\Common Files\ArcGIS\bin\ESRIRegAsm.exe" "C:\mydata\GIS\ArcGISServerFlexAPIData\AO_GP\GPAddFeaturesTool\CSharp\GPAddFeatures\bin\Debug\GPAddFeatures.dll"
please register ARCGIS Installations type:  "Desktop"!
step 2:"Registering the DLL" to Server;
please register ARCGIS Installations type:  "Server"!
step 3:Add Custom GP Tool named Toolbox1;
(1)new toolbox named Toolbox1
(2)add tool named tool1 from register tool dll
step 4:Add Custom GP Tool named Toolbox2;
(1) new toolbox named Toolbox2
(2) new Model named Model1
(3) edit Model1�?Drag the(step 3 tool1)in model1,make variable from parameter...
step 5:Publishing Toolbox2 as service.
Víctor_M_Bajo_Pérez
Thank you very much.
